Stiff throttle pedal
  • 1305 Views
Offline SnowSammi
  • 31
« on: November 29, 2009, 11:01:42 PM »
My 87 Sammi w/stock carb. cable unwound, i replaced it with a Napa cable
pedal very stiff double checked all connections and routing good, help  ???
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
Re: Stiff throttle pedal
« Reply #1 on: November 30, 2009, 03:43:02 PM »
You might need to oil it and let the oil work it's way in for a bit.  Is it stiff even without it hooked up to the carb?
Offline SnowSammi
  • 31
« Reply #2 on: November 30, 2009, 07:01:04 PM »
I'll try that thank you,   no it's not stiff with carb. end unhooked i also
unhooked pedal end with carb. end hooked up feels smooth and normal.
Offline Merlin93
« Reply #3 on: December 02, 2009, 07:08:47 AM »
More stiff throttle cable discussion at:
http://www.suzuki-forums.com/suzuki-jimny-sierra-samurai-forum/33406-throttle-cable-sticks.html
Turns out the final solution was to get an OEM cable. The aftermarket NAPA cable would last only a very short while.
Offline SnowSammi
  • 31
« Reply #4 on: December 02, 2009, 07:08:48 PM »
Well i tried lubing no help so i will buy an OEM cable like i should have done
from the beginning.
thanks again for everyones input :)
