Ok, I have done what Skyhiranger said to do and unbolted the A/C pump and can move it out of the way. Also removed the radiator and fan. I wont be able to remove the engine until next week but now I wonder if there is going to be enough clearance to remove the engine and trans at the same time with the A/C condenser in place? Guess we will see next week.
Hmmm....
if you can get the engine and tranny out as a unit it will take some creative maneuvering......easier thing to do (IMO) would be just to seperate the engine and tranny and remove them one at a time. Why are you taking the tranny out?
If you try to take the engine and tranny out as a unit.....know that if the driveshaft (intermediate shaft) between the tranny and tcase seals the backside of the tranny and keeps the oil in the tranny from leaking out. So you either need to....1) drain the tranny before you attempt to remove it, or 2) unbolt the intermediate shaft from the tcase and make sure it stays stuck in the back of the tranny. It just has a slip yoke on the tranny end of it, so when the tranny is tilted, it will fall out, if not tied/held in place and the oil will run out.
If you take them out individually, you should be able to keep the tranny tilted with the front down to keep the oil from running out.
