Power Problem in 1.6L EFI
  • 7 Replies
  • 1688 Views
Offline vitaradownunder
  • 62
  • Vitara Doin' it Aussie Style
    • WildZooks
« on: June 13, 2006, 01:45:07 AM »
Hi All,
I am running out of power after about 40 to 50 mins of driving... Does not matter how far i have got in that time.
This problem started 8 months ago. Since then i have replaced the rotor button and cap, coil and leads which none of these fixed th porblem. I have replaced fuel pump not even 500kms ago... that seem to work for about 300kms and then back to normal.
Any ideas.
Thanks James
Lets get wild and show the big  toys how to do it suzuki style.
Offline fullsink18
  • 250
  • Wheel Me!
Re: Power Problem in 1.6L EFI
« Reply #1 on: June 13, 2006, 06:19:39 AM »
Did you replace the fuel filter.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
  • 62
    • WildZooks
« Reply #2 on: June 13, 2006, 03:46:39 PM »
Sorry .. yes the fuel filter was changed the same time the fuel pump was........
Thanks James
Offline legionnair
  • 94
  • I hate working lets go wheeling
« Reply #3 on: June 13, 2006, 08:40:35 PM »
I would drain your tank I have heard of people that put plastic bags in the tank and they will float around and suck up against the pump
Also you could check the cat it might start acting up when it gets really hot
or check for engine codes
OOps, owell thats just the fender
Offline Mike71
  • 1449
« Reply #4 on: June 13, 2006, 09:03:43 PM »
i sorta had the same problem when my cat started to go..only got worse from there
id suggest checking the cat its easy enough to un bolt it and see
also the engine with no downpipe sounds frickin mean  :o :o
623hp kb cobra sold! 100hp kick new DD :P
Offline Yoak
  • 577
« Reply #5 on: June 14, 2006, 01:09:16 AM »
I had that happen to me in a tunnel....the header got disc from the exahust....sounded like an engine under there...but sadly it was just my little 8v
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #6 on: June 14, 2006, 06:45:06 AM »
Your problem will probably get worse. Yank the catty and either hollow it out and reinstall, or cut, clear and reweld and reinstall, or replace it with another muffler or straight pipe.  Or then again, maybe it's something else entirely. Any speculation on my part would be pure conjecture.
If all criminals were behind bars, there would be no one left to patrol the streets.
86 Samurai Tin-Top stock with a Harley 44 sidedraft carb
Offline Yoak
  • 577
« Reply #7 on: June 14, 2006, 08:28:29 AM »
As a result of my cat being clogged my manifold ended up cracking....
