Air actuated carrier XL-7/GV
  • 1 Replies
  • 1140 Views
Offline inphobic
  • 43
« on: June 14, 2006, 06:21:56 AM »
Okay so I've got my Gv front axle now for the tracker and I am planning on using a Vitara shaft since I can't find any 96-98 26 spline tracker shafts. I am working on ways to eliminate the air actuator from the front axle. I have ideas on building a shim to hold it in place permanently or even welding the piece in place as well.  Is the carrier even strong enough to take the abuse? I have no plans of ever locking this front diff but the stock open diff didn't hold up either....
If I swap out to a standard carrier then the Vitara CV won't work because the shoulder on the CV is too long.
Any thoughts?
THanks, Jake
www.rubberbellyracing.com
2009 King of the Hammers LCQ!
Looking for Sponsors!
Geo Tracker - Stock Mod RROCK
  • 6554
  • 64
Re: Air actuated carrier XL-7/GV
« Reply #1 on: June 14, 2006, 08:36:56 AM »
Any thoughts?
THanks, Jake
There's an article in the Arvhive section that may help.
http://www.zukiworld.com/main_departments_archive.htm#technical
http://www.zukiworld.com/month_030104/feature_tsb_shiftontheflyremoval.htm
Good luck, Eric
