I went to replace the rear so I went to canadian tire and picked up the replace ment and when I got the shaft off put the new up the the old one to compare size and it looked good.... so I used the seal remover tool the my dad gave me ( screwdriver ) and then looked at the 2 together....outside dia good inside good and thickness ....wrong....it was half the thickness of the original and the new one is rubber with a metal outer and the old is just rubber......anyone else had this....I put the old back in question is could I have used the new one?
