Sidekick j18 engine swap from Esteem j18
  • 8301 Views
Offline kirk
  • I love YaBB 1G - SP1!
« on: March 31, 2009, 12:58:04 PM »
I have a 97, sidekick sport, engine is very tired 155,000 miles, considered rebuild but recycled engines run about $1,000.00.
I looked at a 2001 engine from a Suzuki Esteem with 35,000 miles will this fit into my 97 Sidekick sport  they are both J18 engines except hor. application in the Esteem?
Thanks for the help
Kirk ???
Re: Sidekick j18 engine swap from Esteem j18
« Reply #1 on: March 31, 2009, 01:54:55 PM »
I believe it is the same engine (block and head wise).  I do know some of the engine "components" are different than the sidekick sports.....like the coil packs, for example, the plugs/connectors for them are different.  But you'll just be using the block and head anyway, so that won't matter.
You will probably have to use the sport engine mounts.  I know that the samurai 1.3 engine mounts will fit the 1.3 geo metro blocks......and I am guessing the sport and esteem is the same way.  Same deal with the oil pan.
You will likely have to use the sports intake and exhaust manifolds too.
Offline kirk
« Reply #2 on: March 31, 2009, 02:57:15 PM »
Thanks for the help, I will look a little deeper into the other componets.
Kirk
« Reply #3 on: March 31, 2009, 04:12:44 PM »
At the very least you will probably have to swap your oil pan, oil pump, intake and exhaust.  The Esteme is setup for FWD vs the longitude mount on the Tracker.  Possibly the Distributor as well.  I'm basing this off the 2.0L swap if you pull your engine out of a car, so I could be wrong.  :)
Offline scoutman73
  • 14
  • 1997 Suzuki Sidekick Sport , some mods.
    • Flickr, pics of my Sidekick Sport
« Reply #4 on: March 31, 2009, 05:21:41 PM »
Here is someone on Ebay selling an Esteem eng. and , he says in the description the block and head will work in a Geo Tracker .   http://cgi.ebay.com/ebaymotors/Jdm-Suzuki-Esteem-Geo-Tracker-1-8-Engine_W0QQitemZ360142297653QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item360142297653&_trksid=p4506.c0.m245&_trkparms=65%3A10|39%3A1|240%3A1318
So maybe it will .
Suzuki Sidekick Sport 1997 1.8L auto 4dr.
ZOR winch bumper , Smittybuilt 8000lb winch
RRO rock sliders , 2" body lift, OME springs, struts, Jeff's spacers
Goodyear MTR's 245\75\16, 1.5" wheel spacers
Pics of my Suzuki Sidekick http://www.flickr.com/photos/20915236|removethispart|@N08/sets/72157614268325908/
