Adjustable rev limiter?
  • 1999 Views
Offline suva
  • 35
« on: September 12, 2008, 03:13:07 PM »
I'm pretty hard on my 'kick when I'm wheeling, is there a way to install a rev limiter with the stock ignition?
It's a '98 16v
  • 6551
  • 64
Re: Adjustable rev limiter?
« Reply #1 on: September 12, 2008, 04:04:57 PM »
It's a '98 16v
1.6 16valve engines have a factory rev limiter. Several people on this forum use it a lot. :) Depending on how far your factory tach is off some will swear it's 6800 some say its 7200.... Either way, you have a rev limter if you're using a factory ECM.
Offline pepatt
  • 174
« Reply #2 on: September 12, 2008, 04:18:20 PM »
It's a '98 16v
This should work!   :laugh:
Sorry. I couldn't resist.  ;D
« Last Edit: September 13, 2008, 06:06:04 AM by pepatt »
pepatt
  • 6551
  • 64
« Reply #3 on: September 12, 2008, 05:28:06 PM »
Offline suva
  • 35
« Reply #4 on: September 12, 2008, 05:51:37 PM »
LOL, I was thinking about that on one trip. I swear the valves are floating before the rev limiter kicks in, I was thinking about 5K would be safer for me.
It's a '98 16v
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #5 on: September 13, 2008, 09:27:59 AM »
I've seen guy in mud holes (here in Michigan) bounce off the rev. limiter for what seems like minutes at a time with out any bad results.
I've recently been to the sand dunes and on approch of many hills, I was bouncing the limiter.
96 Tracker
32 MTR's Warn 8000i
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #6 on: September 23, 2008, 07:09:43 PM »
What's the rpm limit on a 94 8V.
    Kevin
