ACOS spacers on the front of a kick
  • 2260 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: August 12, 2008, 10:32:55 AM »
Has anybody ever run these spacers on a kick? I know that they won't just bolt on but you could dial in your suspension just rite.
Offline Z71Edge
  • 87
Re: ACOS spacers on the front of a kick
« Reply #1 on: August 12, 2008, 11:13:55 AM »
From everything I've been reading, Coil Spacers designed for Jeeps (TJ's, XJ's, etc.) will work, BUT you have to drill out the inside diameter to the size that will fit the kicks (can't remember what size off the top of my head). Therefore, unless you can dill out these adjustabe spacers, they will not work. If you could drill them out, I doubt the tube walls will be thick enough for good strength...Just what I am thinking anyways. Anybody else know what Im talking about?
93 Tracker, 1.6L 5spd, 235's on stockers for now...
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: August 12, 2008, 11:56:12 AM »
I was thinking about removing the springretainer/bumpstop extender then mounting the spacer. The part on the kick.
    Kevin
« Reply #3 on: August 12, 2008, 03:57:57 PM »
Never needed to "dial in" my suspension. Just put the right spacers in, and be done with it.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: August 13, 2008, 02:36:46 PM »
Posted by: Jeremiah
Insert Quote
Posted on: August 12, 2008, 11:56:12 AMPosted by: ppltrak
   I like to have my susp. just rite :) I like air time
  Kevin
