GV tie rod ball joint flip
  • 12 Replies
  • 2121 Views
Offline Guardrail
  • 101
« on: November 04, 2005, 04:00:41 PM »
I was thinking of running a Calmini 2.5" lift with coil spacers on my '01 Tracker.  Somebody told me I might get binding in the steering as well as the CV's.  Is there a way I can flip the tie rod ball joint so that the tie rod sits on top of the mount on the upright instead of underneath?  This would reduce the angle on the tie rod quite a bit and may be a simple mod to do.
any opinions welcome.
Can he say that here
Later,
Guardrail
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: GV tie rod ball joint flip
« Reply #1 on: November 04, 2005, 07:41:28 PM »
If you flip the tierods it will change your geometry and drive poorly on the street. The tie rod flip is and off road only mod. I would not recomend running spacers with that kit. The struts will be topped out and ride stiff among other things.
Mike
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #2 on: November 05, 2005, 07:37:18 AM »
There is other ways u can lower the rack a bit not a hard job im gonna look at doing this soon.
01 GRAND VITARA
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #3 on: November 05, 2005, 09:05:32 AM »
Mike
If you reamed out the top of the arm to accept the TRE, would that improve it at all? I would assume a larger TRE would have to be used.
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #4 on: November 05, 2005, 06:19:06 PM »
The problem is the tie rod angle and the lower control arm would different angles of operation  causing bump steer. This is a bad Idea for a street vehicle.
Mike
Offline Gear
  • 112
    • Pics and my club website
« Reply #5 on: November 06, 2005, 01:24:08 AM »
I ran OME struts with the Calmini spacers and didn't have any problems with the steering binding.  the CV's didn't last very long so i now just run it with the OME struts.
Jeff
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
Offline Guardrail
  • 101
« Reply #6 on: November 13, 2005, 12:28:06 AM »
Hey Gear,
How much longer are the OME struts compared to the stock struts and the Calmini struts for a GV?
Later,
Guardrail
Offline Gear
  • 112
« Reply #7 on: November 13, 2005, 01:22:47 PM »
about 40mm longer.
Jeff
Offline Guardrail
  • 101
« Reply #8 on: November 14, 2005, 01:46:44 PM »
Gear,
Didn't you run a spring spacer in combo with the Calmini lift?  Did you have problems with the struts being topped out all the time and the bad ride associated with it?
Later,
Guardrail
Offline Gear
  • 112
« Reply #9 on: November 14, 2005, 01:58:48 PM »
i have 30mm in one side because of a sagged spring and 15mm the other side.  i don't really have any problems with them topping out with just the OME struts (the calmini springs loose alot of height).  The best thing i found for the topping out when offroad is the run the tires at a low pressure so the front doesn't bouce around as much.
Jeff
Offline Guardrail
  • 101
« Reply #10 on: November 14, 2005, 02:05:17 PM »
Anybody know if the OME springs provide as much lift as the Calmini springs by themselves, or are they shorter?
Later,
Guardrail
Offline Gear
  • 112
« Reply #11 on: November 14, 2005, 02:19:21 PM »
no, the OME springs for the GV are shorter.  BUT an option might be to run the new XL7 OME springs in the GV.
Jeff
Offline Guardrail
  • 101
« Reply #12 on: November 14, 2005, 02:24:58 PM »
I don't figure they are much longer, are they a higher rate?
Later,
Guardrail
