removing driveshafts.. (tracker)
stock93tracker
309
March 11, 2007, 02:08:32 PM »
how exactly does one get the damn driveshaft out??!? I took off the 4 bolts (surprisingly none were too seized) and now the thing wont come off
I assume it was just the 4 bolts then the driveshaft should pop off the rear and then I should be able to slide it out off the t/c
93 Geo Tracker
-15 x 7 Rims , 235/75/R15s tires
-2" Lift
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Re: removing driveshafts.. (tracker)
March 11, 2007, 02:15:11 PM »
they stick sometimes. smackthe flange with a rubber mallet
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
stock93tracker
309
March 11, 2007, 02:16:57 PM »
thanks, ill try it..
ironically, I have a rubber mallet in my DD tracker. They're such wonderful tools..
93 Geo Tracker
-2" Lift
stock93tracker
309
Reply #3 on:
March 11, 2007, 02:35:27 PM »
groovy, worked like a charm.. I just didnt want to start smacking it around in case I had to do something else to get it loose (like other bolts or something.
93 Geo Tracker
-2" Lift
ROSS
1412
Reply #4 on:
March 11, 2007, 02:40:28 PM »
I used a wire brush to clean both flanges. and put a thin film of grease on the allignment ring.
makes it come off easier next time. believe me there will be a next time .
stock93tracker
309
Reply #5 on:
March 11, 2007, 02:47:23 PM »
these are just gonna be stored for later use, aint using them yet.
just stripping down what I can on my new parts car for quick use when I break something on the daily driver this summer.
93 Geo Tracker
-2" Lift
