sidekick bolt pattern
  • 10 Replies
  • 6952 Views
Offline bluzukikix
  • 17
« on: December 12, 2008, 01:33:35 PM »
what is the bolt pattern on a suzuki sidekick sport?  5 on 5 or 5 on 5.5?  thanks
Offline okezuki
  • 51
Re: sidekick bolt pattern
« Reply #1 on: December 12, 2008, 01:59:05 PM »
5X5.5
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Offline bluzukikix
  • 17
« Reply #2 on: December 12, 2008, 02:13:54 PM »
thanks
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: December 14, 2008, 12:26:56 PM »
same as a Samurai.
BEWARE!  If you are looking for wheels in the salvage yard, the center hole must be large enough to clear the locking hub!  Not just any 5 x 5.5 wheel will work!
do a search for wheels at Ack's  FAQ.
The link is in my signature.
Ack
Offline bluzukikix
  • 17
« Reply #4 on: December 14, 2008, 03:41:17 PM »
The center hole size never crossed my mind.  Many thanks....
Offline Nicksidekickin
  • 104
« Reply #5 on: December 15, 2008, 12:51:06 PM »
I bought a set of rims from rough country off of a cj7 jeep there the same pattern and gave me a wider wheel base.
1.5 coil spacers front and rear
custom rear bumper
windshield post lights
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Offline Armour
  • 360
« Reply #6 on: December 15, 2008, 05:57:28 PM »
Ford trucks also use 5 on 5.5!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline idaholwb
  • 772
« Reply #7 on: December 15, 2008, 10:48:00 PM »
 Wheelbase? You mean wider track width. Wheelbase is the measurement from the center of the front wheel to the center of the rear wheel.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline JayN
  • 220
« Reply #8 on: December 16, 2008, 05:52:34 PM »
also, there has been talk that 15" wheels will nt fit the sport. trouble clearing the brake calipers.
i have a sport but haven't tried my 15's off my samurai cause they have 32's on them.LOL
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline bluzukikix
  • 17
« Reply #9 on: December 17, 2008, 02:21:58 PM »
Then 15" jeep wheels may not fit... dang.
  • 104
« Reply #10 on: December 17, 2008, 03:00:41 PM »
before you get upset measure the rotor and caliber see what size it is and you can always grind the caliber down some if you can i'm not sure on kicks but on some rigs you can
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
