« Reply #5 on: June 22, 2006, 05:28:34 AM »
Mine was doing the samething. I ended up tighting the snail adjuster on the rear drum brakes. When I did that i found out my wheel cylinder (applies pressure to pads so they hit the drum and slow you down) was shot. But replaced it and tightened the the rear brakes and it went away.
94 2dr kick 8v
- Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3" BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
