my kick don,t like the water i guess!!!!
  • 1522 Views
Offline the joker
  • 37
« on: April 03, 2006, 04:47:37 PM »
was out playin tonite and hit a big old mud puddle alittle too fast and drowned my 93 kick now i can,t get it goin its poppin the fuse for the electronic fuel i dryed every off still no go!!!any ideas!!!!!  ???
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: my kick don,t like the water i guess!!!!
« Reply #1 on: April 03, 2006, 04:58:44 PM »
something electrical must still be wet.  check thru it again.  Maybe starter issues poppin the system fuses too.
1993 4-door Sidekick
4.24:1 t-case
Offline the joker
  • 37
« Reply #2 on: April 03, 2006, 05:25:13 PM »
well think i,ll let in sit for the nite and try again in the mornin!!!!
Offline the joker
  • 37
« Reply #3 on: April 04, 2006, 05:57:06 AM »
well no go today it,s fuse #14 electronic fuel injection main relay 15A i turn the key on and it pop,s any ideas!!!!
Offline Yoak
  • 577
« Reply #4 on: April 04, 2006, 02:24:53 PM »
If you get a repair manual you can see everything that is on that circut so you can be more through with what may be causing it.
You can also try buying that stuff that helps dry out switches and such, not sure what its called though
