Installing Calmini Kick 4.24:1 Xfer case gears
  • 1705 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
« on: March 15, 2004, 12:17:27 AM »
Well, I finally got around to installing the Calmini 4.24:1 transfer case gears in my spare transfer case this weekend.  The instructions are VERY clear, and easy to follow.  Took about 3 hours, I guess.  In two weeks, I'll install the spare xfer case, as well as my new Centerforce clutch!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Re: Installing Calmini Kick 4.24:1 Xfer case gears
« Reply #1 on: March 15, 2004, 12:39:34 AM »
Good to hear it all went good. You will be amazed at thedifference with the 4:1
Offline Rod
« Reply #2 on: March 15, 2004, 11:59:34 AM »
Transfer Case Gears intalled in 3 hours...that's great!
I thought that you had to grind the case and have a machine shop press on/off some of the bearings.
Rod
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #3 on: March 16, 2004, 12:28:29 AM »
No, you remove some aluminum (less than 1/8 inch) with a file (carefully!  I covered the bearing next to where I was removing it, with duct tape, then cleaned it out with a Q-tip coated with grease, THEN cleaned it out with brake parts cleaner.  No machine shop required.  The one bearing I had to pull, I used a screw-type puller on, and everything went back together with a tool I have for seating seals, etc.
Bob
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: March 16, 2004, 08:31:31 AM »
They are easy. Ive been doing them in under an hour consistantly. I use a head porting tool for removing the aluminum and I have a press which helps speed the process.
Mike
