The temperature is hot, the air just doesn't seem to come out where it says it should. On both the Defrost/Floor and the Defrost setting, it still mostly comes out on the floor with only a very small amount coming out on the windshield. It's hovering around 0 degrees here at night, so I need defrost. Is there linkage that needs to be adjusted?
Also, the fan speed is strange.. Off is Off, but any of the other settings is a low speed. The only way I can get the fan to speed up is to put the slider BETWEEN the positions. I'm assuming this might be a medium setting.. Do I need a new resistor?
