just bought a ford 9 inch axle.
  • 8 Replies
  • 1722 Views
Offline satan inside
  • 68
  • bodylifts are for rednecks
« on: October 24, 2007, 09:52:37 PM »
how wide is the one used in the Hagen mod? This one measures 66 inches across from where the wheels mount.
Re: just bought a ford 9 inch axle.
« Reply #1 on: October 25, 2007, 06:54:44 AM »
I will try and get Troy to measure mine. It's a Currie built to Jeep CJ widetrack width, but I bo not remember what that was (I think slightly narrorer than the Kick axle).
  • 68
« Reply #2 on: October 25, 2007, 02:01:29 PM »
I'm thinking it is much wider than stock. like 11 inches. maybe i will cut the tubes off and use it for the front, ala 37kicker's mod. Or i may see how wide it is with zero offset wheels. i plan on running the 39.5 x 16.5 pitbull rockers. I only paid $80 for the axle.
  • 6544
  • 64
« Reply #3 on: October 25, 2007, 03:42:01 PM »
Yeah, that's way too wide to match. If I remember correcly, 58" WMS to WMS is equivelant to a Sidekick axle width. But, you can get aftermarket 9 inch stuff cheap. So save your 3rd member and brakes, the get a housing and axles made to order. You'll still be way ahead.
Offline RHodge
  • 523
« Reply #4 on: October 25, 2007, 07:44:51 PM »
one of this would be nice  ;D
  • 68
« Reply #5 on: October 26, 2007, 01:12:16 AM »
actually if i truss it with this
http://store.summitracing.com/partdetail.asp?part=CEE%2D3405
then it will be stronger than even the 3/8" spider9
« Reply #6 on: October 26, 2007, 10:41:14 AM »
Mine is 54" Back of rotor to back of rotor/ probably making mine 56" WMS to WMS. With my 1.5" spacers it pushes it out a little further thatn stock width.
Offline RHodge
  • 523
« Reply #7 on: October 26, 2007, 01:04:03 PM »
you could cut down the stock housing and have the axel resized and splined
  • 68
« Reply #8 on: October 27, 2007, 02:24:16 AM »
yup. doing a lot of searching on pirate now.
looking to make it 35 spline, full float as cheaply as possible.
i like all the gear options available for it. Thinking of 7.33 ratio  (39.5" tires)
as this will be driven on the street too.
looking to do the front 9" also like 37kicker
