87 sammy tin top roof moves from the bass
  • 7 Replies
  • 2546 Views
ace69247no13
« on: August 12, 2007, 12:12:52 PM »
i have a rather large stereo and dynamat isnt really helping with the movement of the roof from the bass does anybody have any ideas i was thinking of going about it like a stereo shop in oregon and putting in two braces from the floor to the roof one between the front seats and the other either on the box or just behind it
« Last Edit: August 12, 2007, 04:10:17 PM by ace69247no13 »
kingzoo
Re: 87 sammy tin top
« Reply #1 on: August 12, 2007, 01:41:18 PM »
  insulate the bottom of the cabinet so it does not contact the floor or anything.The dynamat between the cabinet and floor will stop a lot of the bad resonance
ace69247no13
« Reply #2 on: August 12, 2007, 04:08:42 PM »
well yes that is true however it is the roof that mooves up and down two inches
Offline SKAsammy
  • 79
  • 1991 samurai
Re: 87 sammy tin top roof moves from the bass
« Reply #3 on: August 13, 2007, 03:24:56 AM »
first i would try turning it down a little, that should help... ;D
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Mudjockey#1
« Reply #4 on: August 13, 2007, 08:45:49 AM »
I had half that system in my Blazer and it hit hard in there, Your system has to thump!!!! 8) 8)  Be careful and check your body screws regularly,  mine loosen a little just from roading the boggers!!! Your thump may wiggle some loose!!! ;D   Keep up the tunes and good luck, That's what I had in mind for my TT thanks for some inspiration to get the build started!!!
« Last Edit: August 13, 2007, 08:49:14 AM by Mudjockey#1 »
Offline mrfuelish
  • 2862
« Reply #5 on: August 13, 2007, 09:40:46 AM »
Cut some ports in the roof and let some pressure out! or get a soft top rig, other wise you might have to make the cabinet bigger going up to the roof and across the top to the driver.
Offline Carnage
  • 2453
« Reply #6 on: August 13, 2007, 10:25:22 AM »
your ROOF moves?
i would def check screws from time to time, crack a window to relieve pressure, basically your rig is like a sealed box, and you got 2 subs in another sealed box, air has to go somewhere and if your SPL is high enough you could blow out
toss a few pads underneath the box for starters
is the box tuned?  is the amp tuned?
ace69247no13
« Reply #7 on: August 13, 2007, 02:46:00 PM »
yes everything is tuned and honestly the roof moves more when the windows are open i need to figure out a way to support it
