Lower timing gear
  • 1023 Views
Offline ldodge92
  • 107
Lower timing gear
« on: June 26, 2012, 12:48:27 PM »
Is the lower timing gear on a 1.6 8v the same as what's on the 1.6 16v? Think that's my problem!
My new addiction
  • 4314
  • 167
Re: Lower timing gear
« Reply #1 on: June 26, 2012, 02:40:12 PM »
It might depend on where you are and what the engine came out of, but, if I assume US, then no, the gears are not the same.
Some, but not all 16v engines have a crank position sensor that detects a toothed wheel on the crank pulley as far as I know, none of the 8v engines have this sensor.
« Last Edit: June 26, 2012, 02:58:41 PM by fordem »
« Reply #2 on: June 27, 2012, 09:15:29 AM »
No.  The 16V gear is wider, because it uses a wider timing belt.  The ODB2 (96 and later) 16Vs also have a crank sensor, so they use a different gear than the earlier 16Vs.  So the later 16V gear will work on an earlier 16V, but the earlier gear won't work on a later 16V.
