venting engine!
  • 1521 Views
Offline budzooka
  • 53
venting engine!
« on: March 27, 2005, 02:45:37 AM »
I have put a toyota carb on my 1.3 and i would like to know what to do with the engine breather line that used to go  to my air filter canister? I plugged it and ended up with some pressure and then some blow by from ??? any ways leaving it open just sends fumes into the cab and i have no line on the carb for it or on my air filter. any help would be appreciated.
Re: venting engine!
« Reply #1 on: March 27, 2005, 03:07:15 AM »
I got one of those little ricer air filters and put it on the end. You could also use a fuel filter of correct size.
Offline budzooka
  • 53
Re: venting engine!
« Reply #2 on: March 27, 2005, 03:08:21 AM »
thank you. what is a ricer filter?
Offline bandit86
  • 1641
  • elv8rguy
Re: venting engine!
« Reply #3 on: March 27, 2005, 03:50:10 AM »
drill a hole on the air cleaner assy and attach a fitting so that the fumes from the crankcase will be sucked in through the carb.  you can find something in your local junkyard that'll work
Offline prairie_dog
  • 234
  • 85/413 tin top
Re: venting engine!
« Reply #4 on: March 27, 2005, 03:30:37 PM »
 Re: ricer filter,  1-2 inch round filter usually found on valve cover ( ford/chev V8 dress up kit) :D :D
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
Offline budzooka
  • 53
Re: venting engine!
« Reply #5 on: March 28, 2005, 01:25:00 AM »
thanks for the help. i have solved that problem and am off to the next one ;D
