95 tracker diagnostics
  • 8 Replies
  • 1657 Views
Offline jputnik
« on: January 27, 2008, 08:30:26 AM »
Got a 95 16 valve  without a 4 prong diagnostic plug, it has a six prong.  when I jump pins 2 and 3 like you would with a 4 prong it doesnt diagnose but just flashes really fast.  I already tried a different ecm and the same thing happens.  The vehicle seems to run fine I just want to know why the check engine light is on.  Any suggestions?
Re: 95 tracker diagnostics
« Reply #1 on: January 27, 2008, 08:45:30 AM »
Have you flipped the CEL switch to try and turn off the light?
On the 6pin diagnostic plug, you jump pins 2 & 4 for codes.
« Reply #2 on: January 27, 2008, 08:51:03 AM »
Offline jputnik
« Reply #3 on: January 27, 2008, 12:19:45 PM »
Thanks guys! everything worked perfectly
phloop
« Reply #4 on: January 27, 2008, 12:31:02 PM »
Where would I find this plug? I have a 95 16v also that is having an issue or two that I would like to fix.
« Reply #5 on: January 28, 2008, 04:46:33 AM »
The plug is usually to the battery or behind the (US) passenger side headlight. It has a rubber cover over it.
phloop
« Reply #6 on: January 28, 2008, 09:51:33 PM »
This morning I think I noticed a plug like that when I was hooking up the Bat. It was attached to a relay, fuse box thingie next to the bat. just in front of it which was bolted to the fender.
I'll check it in the morning when I hook the bat. up again.
Offline gearjam
  • 97
  • RC 2010
« Reply #7 on: January 29, 2008, 04:08:59 AM »
My 95 has an OBD2 connector under the dash that the engine codes can be read from. If you have one of these Autozone will read your codes for FREE.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: January 29, 2008, 01:05:27 PM »
How curious!  All of my 95's have been OBD1!  Where did you get this beast?
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
