Just to add some more info to the pics above this is what he said he did.
"As u can see there is not much lift on it, i used 2, 10mm OME coil spacers for a jeep TJ front, all round(stock springs), i then proceded to tear the whole inner guard out, smash the firewall back 4 inches, remove the exelorator stop, extend the bumpstops on the rear about 5 inches to help tip the wheel in on compression, force droop and stop the srings from falling out. I also put 3insh strutt jacks in the front.
Not shure what offset the rims are, but yes it is alot
5.12's are not enough gearing, it will need a rockhopper.
Thats right, i unpicked the rear wheel arch, removed some guard, then eurathaned it up. "
