Oyea, Wild,,,,I just got the MS yesterday. It doesn't look that bad.
Ya, a couple of nights soldering and it will be done,
use the online manual to assemble it, and do all the
tests along the way as you build, this way if there is
a problem, you will know it right away, as well know
where to look for the problem.
Practice your soldering before you start on the MS
and get a small soldering iron to work with, much
easier when working on those small joints and in
tight spots
Did you get the Digi-key order yet ? I would order
it all from them on the auto order system
