27 spline diff?
  • 10 Replies
  • 1832 Views
Offline dave
  • 31
  • I love YaBB 1G - SP1!
27 spline diff?
« on: November 22, 2005, 02:33:43 AM »
I want to build a costum axle for my vitara. I want to use a dana 44 axle and but a sidekick rear diff in it. My biggest problem is that the rear diff has 26 spline axles and a dana 44 has 27 spline axles...
How could a solve this problem? Respline the 27 axles to 26 axles or does there exist a adjustment so i can put in a diff with 27 splines?
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: 27 spline diff?
« Reply #1 on: November 22, 2005, 06:12:15 AM »
Why would you want to put a Sidekick diff in a Dana 44?  That just doesn't make much sense to me.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline dave
  • 31
Re: 27 spline diff?
« Reply #2 on: November 22, 2005, 06:53:53 AM »
I want to keep my rear axle so i must have the same R&P's. I've allready invested in a rear locker and the 4.30 R&p is also here so i don't want to trew that all away.
Offline SnoFalls
  • 1358
Re: 27 spline diff?
« Reply #3 on: November 22, 2005, 08:16:15 AM »
Dave,
I'd suggest either 4.88 or 5.12 for the D44 and then get a kick/trac r/p to match. other choices for the D44 are 5.38 or 5.89. The 5.38 does exist in certain trac/kick diffs, so that's another option.
IMO the 4.30 you have now is too tall a gear anyway ...
« Last Edit: November 22, 2005, 08:20:10 AM by SnoFalls »
Offline dave
  • 31
Re: 27 spline diff?
« Reply #4 on: November 22, 2005, 10:08:09 AM »
I have a sam gearbox, thats why the R&P is that large.
(I could drive a 38" tire and rev's as much as stock gearing with stock tires if i would use the 5.125 gears.)
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: 27 spline diff?
« Reply #5 on: November 22, 2005, 10:20:10 AM »
Seriously - you will be far better movig the D44 and the Kick Diff to a common gear ratio, than trying to fit a Kick diff into a D44 axle.
Bob
Offline dave
  • 31
Re: 27 spline diff?
« Reply #6 on: November 22, 2005, 10:25:08 AM »
Yes, i know. A 4.27 gearing for a dana 44 does also exist. But that would be probably not exact enough to fit with a 4.30 in the sidekick axle?
Offline SnoFalls
  • 1358
Re: 27 spline diff?
« Reply #7 on: November 22, 2005, 10:31:46 AM »
ah ... didn't know that ...  ;D
4.88's are *only* another 13% lower than the 4.30's ... (I believe that's a 99+ AT with 2.0l)
Offline dave
  • 31
Re: 27 spline diff?
« Reply #8 on: November 22, 2005, 10:39:10 AM »
I 'm thinking about buying a rear dana axle to. Will make my life a little bit easy'er i think.
Mayby I thake 4.10 r&p's in it so i can reduce my gearing even more with my sam case (a 4.16 or 6.1)
What are the best axles to use? Wagoneer axles ? Do they have correct bolt patterns?
Offline SnoFalls
  • 1358
Re: 27 spline diff?
« Reply #9 on: November 22, 2005, 11:17:54 AM »
waggy axels are pretty good choice if your set on 44's ... get around a '78 (pass drop and flattop knuckles) and they measure out about 2" wider than a kick (60.5" waggy vs 58" on a kick) ...
Offline cj
  • 1276
  • I drive a really big ATV
Re: 27 spline diff?
« Reply #10 on: November 22, 2005, 01:37:32 PM »
Do a search as I posted some details about 27 spline axles and full floaters. If you have a Kick with a rear ARB locker you can get replacement sidegears for 27 spline axles as well as D44 30 spline axles. I have physically seen these myself at ARB HQ in OZ.
« Last Edit: November 22, 2005, 01:39:45 PM by cj »
