I took the body lift out of my 91 tracker one evening. Then when I fired it up to drive out of the shop the Check engine light was on. I looked under the hood and found the main ground wire had fallen off. I was not too sure where it was bolted to so I bolted it to the top mount of the alternator which was also missing the nut. It didn't fix the problem. It sputters on cold start and has "flat spots" in the accelleration. Any ideas what it might be? It's kinda frustrating cause I put a turbo in it but it's not running as well as it aught to. I took it into a shop (not my idea of a good time, I prefer to fix it myself) but the scan would only temporarily clear the codes. I thought maybe a new 02 sensor, but that didn't fix it either. I thought also maybe a bad ground. Where does it bolt on to yours?
