Hey everyone. I lost my instrument panel check lights - battery, brake, check engine, seatbelt, etc.. I've got a 93 4dr track/kick. Here's what happened. I killed the battery. Then jumpstarted it, hooked stuff up wrong and ended up blowing the 60a fuse that sits next to the battery. Replaced the fuse. Jumpstarted her.
Now the warning lights across the top don't work. I checked the fuses all are good. Checked the bulbs, all good. Is there any other place the system could fail? Fuses other then the fuse box under the dash? Any suggestions? Thanks!
