87 sami transmission problems
  • 1022 Views
Offline nosaj
« on: April 17, 2007, 08:15:21 PM »
my 87 sami just started getting slippery in the gears and has a tendency to stick in third gear. need to know where the fluid res. is so i have a place to start. any other info or suggestions would be helpful. thanks
jason
Offline Amilla
  • 1076
Re: 87 sami transmission problems
« Reply #1 on: April 18, 2007, 10:05:53 AM »
What do you mean by the gears are slippery, and sticking in 3rd?
The check plug is on the left side of the tranny (if you were looking from the rear)
Amilla
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #2 on: April 18, 2007, 11:32:41 AM »
toomey has three trannys for cheap if all else fails  Check with him  801-420-4970
Offline Java110
  • 59
« Reply #3 on: April 18, 2007, 02:39:26 PM »
is it an automatic?
