93 Tracker won't start..?
  • 1205 Views
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
« on: January 19, 2009, 09:09:30 AM »
Don't know what else to look for, Timing right on , new belt, gettin gas and spark, new computer, plugs, wires, cap, good compression. Cranks over really good.
Ran great then one day it started losing power, would hardly pull itself out of it's own way, then just quit running, haven't been able to get it to start since.Help! any info you may have I may need!
Thanks Ahead!
If I Can't Weld It          It Can't Be Welded
Offline zukizuki07
  • 251
Re: 93 Tracker won't start..?
« Reply #1 on: January 19, 2009, 10:44:32 AM »
checked the compression?? also where/how did you check that it is getting fuel?
96 2 Door Tracker
Offline Armour
  • 360
« Reply #2 on: January 19, 2009, 11:16:24 AM »
Make sure you have a strong enough battery! Mine wouldn't start once and it was the battery was low! Hooked it up to the charger and it fired up!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline idaholwb
  • 772
« Reply #3 on: January 19, 2009, 12:49:10 PM »
I've run across this problem many times over the years. Check the inside of the timing gear and end of the crankshaft where the keyway is. If there is any slop or wear on either the gear, key, or keyway then it means you need to repair/replace accordingly. there is no "quick fix". If the crank is good you can just buy a new gear and key from the dealer. It's less than $50 for both. If you need it, I can get you the correct part numbers for your truck.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ghd23
  • 406
« Reply #4 on: January 19, 2009, 08:29:09 PM »
Crank, pulley,gear and keyway are all in great shape!  battery is new, when I turn the key on gas sprays from the TBI.
Offline SNJSamurai
  • 386
« Reply #5 on: January 20, 2009, 12:27:11 AM »
throttle position sensor, crank sensor, cam sensor
did u replace the battery after it died? it could of been the alternator. and dont trust 12 volts at the battery get it tested at autozone for amps
Bob
