2.5 to 2.7 swap in 2000 Grand Vitara
  • 95 Replies
  • 60085 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: 2.5 to 2.7 swap in 2000 Grand Vitara
« Reply #30 on: February 08, 2005, 01:58:16 AM »
Another question do you have email STUNT?
How big are the downpipes on the 2.5 inch wise?
01 GRAND VITARA
Offline stunt
  • 47
« Reply #31 on: February 08, 2005, 02:16:29 AM »
I made my email visible in my profile.  The downpipes look to be maybe 2" or so.  I'll meassure them.  There isn't much there other than the pre-cats and the pre-cats look identical to the ones on the 2.7.
I think it makes more sense to leave the 2.7 intake on the 2.7 bottom end.  If I was going to use the 2.5 ECU and harness on the 2.7, I would agree that swapping out the intake would make sense.
« Last Edit: February 08, 2005, 02:21:50 AM by stunt »
Offline JDMCRX
  • 1110
« Reply #32 on: February 08, 2005, 03:39:46 AM »
Yeah sorry about the intakes i just read i forgot u were using the 2.7 wiring harnes.
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #33 on: February 08, 2005, 04:52:15 AM »
Is it possible to post more pics also
can u take a pic of the exhaust manifolds thanks STUNT like the welds on the cats and ports.
The truck i got has a cracked manifold
01 GRAND VITARA
Offline stunt
  • 47
« Reply #34 on: February 08, 2005, 01:58:34 PM »
I tore into the bottom end of the 2.5 to get it unsiezed so that I could turn the crank to get at the converter bolts since I need it for the 2.7.
Here is what I found on rod journal #3:
A close up of the cap and upper bearing:
The oil pump was fine, but the pickup tube screen certainly appears to be a little on the clogged side...
There doesn't appear to be any other damage that I can tell, so a new rod and a polish of the crank journal just might get the engine back on its feet although a complete teardown would probably be a better bet.
The cranks turns by hand now, so I was able to unbolt the converter and flywheel, so I'm now ready to prep the 2.7 for installation.
« Last Edit: February 08, 2005, 02:09:41 PM by stunt »
Offline stunt
  • 47
« Reply #35 on: February 08, 2005, 02:06:44 PM »
Here you go JDMCRX.  The other side is very similar.
Offline JDMCRX
  • 1110
« Reply #36 on: February 09, 2005, 12:55:15 AM »
Hey stunt i sent u a email from joshbeauchamp|removethispart|@yahoo.com
I need to purchase some stuff off u im sort of in a bind lol
thanks for the pics please email me back
josh
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #37 on: February 09, 2005, 01:48:37 AM »
Thanks STNUT for the pics do u have any pics of the cyl head as in cams also the pistons and cyl comp chamber.
More pics the marryier. Just would like to know what this motor looks like inside if u can email them to me i can host them if you can not.
Also does a 2001 have a MASS AIR or is MAP sensor?
01 GRAND VITARA
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #38 on: February 09, 2005, 02:24:19 AM »
I just wanted to say,
I LOVE the pictures in this topic, and I love reading this.
THANKS!
Heather Galvin
Offline stunt
  • 47
« Reply #39 on: February 09, 2005, 03:39:50 PM »
Thanks Heather!  I'm also very appreciative of the feedback I'm getting.  A week ago, I had never not so much as turned a bolt on a Suzuki.  I 4x4 with the best of them, but my choice of iron comes from within the US borders (current rig is a '02 Silverado 3500 duramax crew cab long bed w/ a 15000 Warn winch out front running BFG 235/85/16s ATs).
So you guys want pictures?  Well, here you go!
WARNING!  If you click on the "Full Rez" link below each pic, you'll get a 6.3 Mega Pixel version of the image (I'm using a Canon Digital Rebel).
Me and Rufus looking at the mess I've made (okay, Rufus is looking at the camera ;))
Full Rez
And here are several shots of the 2.5 from various anlges:
Full Rez
Full Rez
Full Rez
Full Rez
Full Rez
Full Rez
« Last Edit: February 09, 2005, 03:41:40 PM by stunt »
« Reply #40 on: February 09, 2005, 09:41:38 PM »
Yea awesome thread. I have absolutely no use for this knowledge but keep coming back ;D Keep it coming  8)
95xl7
« Reply #41 on: February 09, 2005, 10:26:44 PM »
How often did you change your oil? Were you using synthetic? The motor sure looks sludged up.
Offline stunt
  • 47
« Reply #42 on: February 10, 2005, 12:14:45 AM »
It's VERY sludged up.  I just got married a couple of months ago, but the wife states that she had the oil changed at Jiffy Lube every 3000 miles.  Ironically, I did change the oil once, 1 month ago, and the old oil was blacker than the oil in my diesel truck!  No, I didn't use synthetic and I'm sure Jiffy Lube didn't either.
I do run synthetic in my other rides, so would you recommend that I switch to say, Mobil 1 synthetic 5w-30 in the 2.7?
Offline Cwkick
  • 888
« Reply #43 on: February 10, 2005, 01:03:51 AM »
Often time Jiffy Lube uses Penzoil.
Penzoil used to be the best oil you could get.  Once they lost the rights to the Pennsylvania crude oil reserves they started use a lot of paraffin (wax) in their oil.
Now it sucks.
Cwkick
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #44 on: February 10, 2005, 09:38:11 AM »
I used penzoil once in my 2.0 Tracker and the inside went from looking shinny and new, to dull and brown. Also some shops won't change your filter if it's in a hard to reach/remove area but they will tell you they did >:(, did my own little experiment once and found that out. The only reason I take my vehicle to a shop is for state inspections and I watch them like a hawk.
« Last Edit: February 10, 2005, 09:39:34 AM by 97TRAKIN »
