tracker rear shocks longer than crown vics or f-150
  • 1364 Views
Offline joe dirt
  • 148
« on: April 22, 2010, 04:55:29 PM »
im looking for a set of rear shocks that are longer then the common crown vics or f-150's...im running tj coils moved tto the bottom of the frame, gaining 4 1/2 inches over what the tj's give me..roughly 8 1/2" lift
wondering if im forced to but an aftermarket lift shock,..
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Re: tracker rear shocks longer than crown vics or f-150
« Reply #1 on: April 22, 2010, 07:50:41 PM »
F-150 shocks are quite a bit longer that Crown Vic shocks, you need longer than that?
Offline joe dirt
  • 148
« Reply #2 on: April 22, 2010, 08:56:45 PM »
you wouldnt happen to have the length on the f-150 shocks would you?...i thought the f-150 ones were about the same size as the vic's??
« Reply #3 on: April 22, 2010, 09:46:35 PM »
I don't have the length, but the F-150 shock had to be fully compressed
to get it on the back of the Kick, and the Crown Vic shock works perfectly
with my 3" lifted springs.
I looked up 3 different lengths, depending on the type and year of the F-150,
starting at 26, 24 and 22, extended length, so I would measure your normal
ride height and pick a shock that is in the center of it's stroke for the length
you need
« Last Edit: April 22, 2010, 10:01:48 PM by wildgoody »
