1987 samurai 5 speed trans problem helpppppp!!!!!!
  • 1571 Views
Offline lilredsami92
  • 11
« on: July 14, 2012, 12:00:27 PM »
ok so my sami will not go in to any gear with the motor on or off have no clue what it wrong pls help?
if u cant find 'em, grind 'em!!!!!!!!!!
Offline kbeefy
  • 17
Re: 1987 samurai 5 speed trans problem helpppppp!!!!!!
« Reply #1 on: July 14, 2012, 12:18:41 PM »
how sloppy is your shifter? I'd guess either a worn out/broken shifter+sheet(bushing) or something internal broken. Pull the shift lever and check it out.
  • 11
« Reply #2 on: July 14, 2012, 12:26:27 PM »
it will go side to side but around 3rd and 4th gear it catches on something also i dont really kno what to look for
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: July 14, 2012, 12:37:59 PM »
This is most likely your problem and the cure....
http://www.zukioffroad.com/Tech_Library/transmission_shifter.shtml
  • 11
« Reply #4 on: July 14, 2012, 12:42:15 PM »
ok thanks ill be working on it again tomorrow so ill chech it out tomorrow
  • 11
« Reply #5 on: July 15, 2012, 10:53:28 AM »
ok so i got it to go into gear but when i let off the clutch it doesn't move
