Further progression of FJ80 axle install (pics)
  • 2253 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: March 05, 2005, 02:11:46 PM »
Just a few more things to do.
1 get rear shocks
2 get drivelines
3 wire up elockers
That's it!
Steering is done, all four tires are now on the ground. See pictures here:
http://www.granitepath.com/friends/kd7hcg/pictures/toyaxles/toyaxles3/index.html
Teasers:
More to come soon! We should have flex shots by next weekend!
Heather
« Last Edit: March 06, 2005, 01:44:41 PM by hcgalvin »
Heather Galvin
Re: Further progression of FJ80 axle install (pics
« Reply #1 on: March 05, 2005, 03:30:48 PM »
Looking good as always ;D
If ya get bored, I'll bring my stuff out ;) ;D
Sure glad your all not shy with the camera.
Keep the pics coming ;D ;D ;D
« Last Edit: March 05, 2005, 05:56:43 PM by trickker »
Offline blyota91
  • 71
« Reply #2 on: March 06, 2005, 06:46:19 AM »
That things not going to fit in the garage soon!
1988 Samurai 5inch SPOA and 32X9.5 TSL's  Giggity Giggity
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: March 06, 2005, 07:33:44 AM »
It already doesn't.
We have to air the tires down to get out!
:o  ;D
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: March 06, 2005, 01:47:31 PM »
Welp,
We put on a front swaybar, basically just took the old one (the sammy one that we had modified to mount to the Ubolt plates) and put it back on the front. It was the easiest. The FJ80 swaybar was just a little TOO big- wouldn't have fit in very easy.
We bled the brakes and rolled it around in the garage, it stops QUICK - (eeerch) but I can't wait to test it out on the street.
We built the rear spare tire bracket, and put in the new replacement chromoly coupler into our Kicker 3 that OTT sent us with our steering arm. This way, the Kicker 3 will be pretty much bullet proof.
Now, all we have to do is get some rear shocks, get some drivelines, and wire up the elockers. It's almost done.
« Last Edit: March 06, 2005, 01:48:08 PM by hcgalvin »
Heather Galvin
« Reply #5 on: March 06, 2005, 04:58:37 PM »
Did ya tear yours up?
Pics
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #6 on: March 07, 2005, 01:50:55 AM »
Pics
Well, the first several Kicker 3's that OTT made came with couplers that ended up being softer than the shafts in either transfer case. The coupler connects the two transfer cases together:
When the coupler would spin on the shafts, with any vibration, because it was softer, the splines inside would wear out.
The Kicker 3's are now coming with chromoly couplers, so that does not happen any more. And I was sent a chromoly replacement as a "warranty replacement" by OTT with my knuckle. They are a good company, just a little slow at times. I am sure it's because they are small.
Heather
« Last Edit: March 07, 2005, 01:52:20 AM by hcgalvin »
Heather Galvin
