Thanks man should I get some type of manual for reference or just take some pics?
It's not too bad, just don't mix up the parts,
and you might want 2 pairs of hands, there
are some spring loaded parts that will be easier
to assemble that way.
Make sure you keep track of where the ball bearings
go on the plate between the halvs of the body and
use a little sticky grease to keep them in place during
assembly.
The hardest part is getting the kick down linkage cable
off of the cam, and the shortest tube on the botton is
a little hard to get in, but they just slide in and are snug fit
