My '87 Samurai slides into 4WD high range fiine, but sometimes won't go into 4WD low range. I start from a full stop, manually lock the front hubs, depress the clutch and try to move the transfer gear lever into the low range, and it won't go sometimes. Does the regular 5 speed shifter have to be in any special position besides neutral? Anybody got any ideas? Could it be that the clutch is not disengaging enough although normal shifting is fine?
Gene
