1.3 EFI to 1.6 EFI
  • 1349 Views
Offline mudbug
  • Mudbugging
1.3 EFI to 1.6 EFI
« on: April 06, 2005, 10:58:36 AM »
Can anybody tell me if it is possible to swap a 1.3 for a 1.6 using the ECM from the 1.3 EFI?  Both are fuel injected.  1.6 is out of a 94 tracker and the 1.3 is in a 91 Sammy.  I want to do the swap but the ECM in the 1.6 is bad.  Please help?
Jeeps are for people who can't handle a Suzuki!!!
Re: 1.3 EFI to 1.6 EFI
« Reply #1 on: April 06, 2005, 04:45:35 PM »
If the injector is bigger on the 1.6
than the 1.3 system I bet it would
work fine, then again 300CC increase
isn't too hard for an EFI system to
work with and compensate for
No problem swapping, you might
as well try it and report back
Offline mudbug
  • Mudbugging
« Reply #2 on: April 07, 2005, 02:05:07 PM »
I know that I have to get an adapter to fit the tranny to the 1.6, but what else would I have to do to fit the 1.6 in the Sammy?
The reason that I want to pull the 1.6 out of the Tracker is because something in the wiring or computer keeps blowing the fuse for the fuel pump.  The pump seems to be fine and all of the wiring from the tank to the fuse panel is good.  If any body has any suggetions about either situation, please post a reply.
