WTB 1992 Geo Tracker heater/ AC blower switch
  • 3000 Views
« on: September 29, 2012, 04:11:27 PM »
Hello everybody!
I am looking for a blower switch for my 1992 Geo Tracker.
I need to replace it because the blower that I have right now runs only in one position.
I have found one on the web but I don't know if it's gonna work on my car, so I need some help with this.
Will this work for me? AIRTEX 1S1755 Switch, Blower
HVAC Blower Control Switch
I found it on Ebay, this is the link: http://www.ebay.com/itm/AIRTEX-1S1755-Switch-Blower-/160848923140?fits=Make:Geo|Model:Tracker&hash=item257357ca04&item=160848923140&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Thanks!!!  :)
Offline Joe Llamahead
  • 209
  • 9
Re: WTB 1992 Geo Tracker heater/ AC blower switch
« Reply #1 on: September 29, 2012, 10:44:12 PM »
I can offer some general information  : most blower capered controlls use a resistor cluster  in series to drop voltage for lower speeds , o if it only works on high , then thi is likely to be the issue. Again generally speaking theses resistor clusters are typically mounted in he plenum so that the. Blower air runs across them and cools th e resistors. If theses r the case I would also inspect the fan for leaves And or rodent nests.  Typically what leads to the failure of h resistors
Offline krittergitter
  • 114
« Reply #2 on: September 30, 2012, 12:46:09 PM »
I hav a couple of switches
Offline smife
  • 179
« Reply #3 on: September 30, 2012, 04:53:04 PM »
Joe is correct. It could just be the resistor........ If the switch itself has a funny feel to it when switching between speeds start there. I have replained resistors, they set under the dash on the pass. side in the fan housing.
« Reply #4 on: October 13, 2012, 12:51:21 PM »
Hello Smife!
Thanks for the tip!
How much would you like for those in case you sell them to me?
Thanks!!!
Also, Should you consider buying the switches also since they don't work properly?
