Track/Kick/X90 rear driveshaft needed ASAP in PA
  • 1009 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: May 20, 2012, 05:55:30 PM »
My son's X-90 just destroyed the rear driveshaft at the front universal. Trashed the ears of the shaft, too. So he needs a rear driveshaft complete from slipyoke to the flange at the pinion yoke. I imagine that it's the same for 2 door 4x4 track/kicks as well. I had him remove the drive shaft from the flange and he is limping it around in 4wd for a front drive right now, but he needs to get a drive shaft as soon as possible. Can anyone help him out? Please let me know. Thanks.
reply here, send me a pm or email me at SnakebiteEMS ("at" symbol) hotmail (dot) com
Re: Track/Kick/X90 rear driveshaft needed ASAP in PA
« Reply #1 on: May 21, 2012, 03:51:48 AM »
Hey man. Trail Tough bought out most of Hawks used part supply. Give them a shout, that is where I use to get mine...
Offline krittergitter
  • 114
« Reply #2 on: June 17, 2012, 06:35:04 PM »
i hav a tracker driveshaft
Offline talonxracer
  • 1284
« Reply #3 on: June 17, 2012, 07:30:26 PM »
Make sure you get the correctly splined slipyoke equipped driveshaft, fairly certain the X90's all had course spline rear output shafts(96'+ 2dr).
