Lots of Samurai Parts 16 Valve, Garrett Turbo, TT 5-speed, TT T-case
  • 14 Replies
  • 3967 Views
I have decided to do a complete drivetrain swap on my rig so I am selling everything that is coming out. I have everything you need to build a Samurai. If there is something you need and don't see it on the list let me know. Everything is still in the rig and if you hurry you can drive it before the parts are removed. This is a well maintained rig and everythink is in very good shape.
JDM 1.6 16 valve motor with
95 intake and Doug Thorley header:  SOLD
New Garrett T-25 Turbo
Turbo Exhaust Manifold and Flange
Autometer boost guage. You will
need the exhaust flange,
oil return flange, and tubing
Here's a link to the turbo manifold
http://www.jgstools.com/turbo/thk.html $500
Trail Tough 5 Speed:  Pending Payment
OEM 5 speed: SOLD
Trail Tough T-case 4.16 gears
Evil Twin twin sticks :  SOLD
Stock T-case with case
that has been welded: Pending Payment
Built 1.6 16 valve bottom end
Pauter Rods
Arp head studs and main studs:  SOLD
17" Mickey Thompson
Bullet hole wheel with
37" BFG KRT-b sticky tire $200
Lowrance 540c GPS :  SOLD
Dual O2 pumpers
with Helmet tubing $100
New Tracker Fuel Pump       $20
Engine Belts             $5 a piece
2000 S-10 Gas Tank   $30
1995 Tracker MAF       $25
1995 Tracker ECM :  SOLD
Electric Fan    $20
Brake Booster  $15
16 Valve Injectors  $20
I also have lots of random spare parts like water pumps, brake master cylinder, ECM, MAF sensor, coils, igniters,electric fans, fuel pump, throttle cables, pedals, window nets, etc. etc.
If interested in any of the parts you can call me at 615-456-7185. I will try to post some pictures and videos this weekend. All the parts are located in Lebanon , TN. If you need pictures of something specific please ask, because I can't post pictures of everything. All prices do not include shipping so keep that in mind.
I figured I would post a pic of the rig all of the parts are coming out of.  Many of you know this buggy and the good parts it has in it.
Thanks for looking.
« Last Edit: June 18, 2011, 09:45:58 AM by jcorlew24 »
Offline CAMELPRO
  • "Her name is Suzi."
Re: Lots of Samurai Parts 16 Valve, Garrett Turbo, TT 5-speed, TT T-case
« Reply #1 on: June 13, 2011, 06:05:32 PM »
Is the motor fuel injected or carbureted?
88.5 Suzuki Samurai
6.5 Transfer case gears
6" YJ Spring over
2.5"lift springs
OTT Stage I Steering
40x13.50R17 Pro Comp XTerrains
Stock 1.3L + header at the moment
Stock axles at the moment
« Reply #2 on: June 13, 2011, 07:21:38 PM »
The motor is fuel injected.  All PM's answered.  The OEM 5 speed is pending pickup.
« Reply #3 on: June 13, 2011, 07:38:28 PM »
Love the rig! I need that GPS but just can't swing the cash right now(too many other parts to buy)
« Reply #4 on: June 14, 2011, 04:30:50 AM »
Are you still running samurai bolt pattern? Or have you switched to Toy axles?
Good to see someone else 'local' on the forum... Welcome...
« Reply #5 on: June 14, 2011, 04:53:45 AM »
I am running FJ80 axles. The front is a Diamond housing with Longs and the rear is stock axle with 4340 shafts.
« Reply #6 on: June 14, 2011, 04:54:54 AM »
I understand the feeling.  I am having to sale all of these parts to front the parts for my drive train.  The GPS is one of those parts I hope doesn't sale.
« Reply #7 on: June 14, 2011, 06:24:18 AM »
-Does th FJ80 have the same bolt pattern as the Toy Mini truck axles?
-Any damage to the rims? I have a bent one now and it's driving me NUTS!
-Is the $200 for the set?
« Last Edit: June 14, 2011, 06:34:06 AM by Zukipilot »
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #8 on: June 14, 2011, 10:02:08 AM »
i called ph # your in MN,  might be interested in welded tcase,give me a call   stan   715 377 6993
« Reply #9 on: June 14, 2011, 03:07:06 PM »
Sorry I have been very busy today.  Another local guy wanted it, but he never called back.  I am in TN you can try me again anytime.
« Reply #10 on: June 14, 2011, 03:10:19 PM »
16 Valve Motor, stock transmission, and GPS are pending on payment.
Thanks for all the interest.  I can't believe no one hasn't jumped on that Trail Tough transfer case. I figured it would have gone first.  I have had a ton of interest in it, but still have it.
« Reply #11 on: June 15, 2011, 07:19:11 PM »
Edited list and added pictures of what is left.
Trail Tough 5 speed
Turbo Setup
Brake Booster
Electric Fan
Injectors
ECM
MAF
Fuel Pump
OEM T-case
« Reply #12 on: June 15, 2011, 07:21:40 PM »
Welded case
Trail Tough T-Case
« Reply #13 on: June 16, 2011, 08:13:22 PM »
Trail Tough 5 speed is back up for sale.  For those of you who are pissed at me for not holding parts without payment.  This is the perfect scenario why not to do that.
Offline tbr310
  • 9
« Reply #14 on: July 26, 2011, 04:36:20 PM »
Interested in turbo set-up. Price shipped to 92544.
Thanks.
