Somebody make me sane and buy this thing!
Only $3,000 OBO (needs assembled) Kinda know nobody will buy it, but entertain me!
$1,700 in machine work alone (Nearly $1,500 in bottom end, $206 in top end). Crankshaft still needs to be sent off to be nitride treated (~$200)
3 angle valve job, 1 valve replaced
Head milled .015"
DIY PnP / gasket matched
Head tanked/cleaned
Ported stock intake mani
Block decked
Block inspected
ARP head studs
ARP rod bolts
Mains decked and line honed
Cylinders bored/honed for 75.5mm pistons
75.5mm YCP Vitara Pistons with teflon coated skirts
Honda D16z6 crankshaft (mains machined down to fit G16 block, flange holes plugged and drilled/tapped for Tracker flexplate, snout machined down nearly 1/2", keyway recut, machined down for oil pump to fit, machined for thrust bearing relocation, balanced)
Nitride treatment for the crank (soon, $200)
FJT D16 custom length i-beam rods
New oil pump
OEM Honda D16 size ACT Race bearings for the rods
Clevite thrust bearings
Sealed Power main bearings
Mazda e-bay cheapo turbo mani (will probably trash and make my own)
TB25 off a Saab, rebuilt (probably wont last LOL)
Ebay 'type-s' BOV. (best fake one according to the Honda guys haha)
Full gasket set
Waterpump
Gates Timing set
