Selling/parting out 1.3L Motor from '87 Samurai
  • 999 Views
« on: April 25, 2012, 06:50:07 AM »
The motor ran strong and Idled smoothly. It started smoking blue smoke so I'm assuming it has bad oil rings) so I'm swapping a TD in it. Needless to say I don't need this anymore and the swap is costing more than anticipated. The engine has 131k miles (at least that is what the odometer on the samurai says). I've started to disassemble the head from the block to get it ready for scrapping
All reasonable offers will be accepted. The only thing not available from the motor is oil and temp sensor (needing for the swap)
Also, I have a starter that I bought just before I did the swap from Autozone. It has been used less than a dozen times. I will give my phone number so that you can have the lifetime warranty with it. Paid ~$110 for it but I will take $40 + shipping from 37327
One more thing, I believe the carbeurator is aftermarket. It has a couple of adapters connected between the carb and the intake. It says Weber on it butvim not sure if those are factory or not
« Last Edit: April 25, 2012, 07:18:10 AM by voodoo22007 »
Offline truckurai
  • 33
Re: Selling/parting out 1.3L Motor from '87 Samurai
« Reply #1 on: April 26, 2012, 04:59:00 PM »
how much for the carburator setup shipped to 43050?
Offline stovokor
  • 27
« Reply #2 on: May 17, 2012, 08:44:35 PM »
how much for the crank and pistons/con rods shiped to 98387
