OK, I now understand why no one add's a forwarding link and just tell us to use the forum search because this forum is not set up in a way we can subscribe to the different threads we are interested in! ERRRR!
OK, so I am interested in finding (see article archives "Zig's Beef)
SO, I go and type in "Zig's Beef" in the Search window and get these two results:
[1]Diffs- r-diff spacer & fr-diff pinion mount
http://www.zukiworld.com/forum/index.php?topic=3032.0[2] Sidekick-Lockers-front alum.casing
http://www.zukiworld.com/forum/index.php?topic=4002.0 OK, I'm on Page:2 and will just continue reading, but it is very frustrating when you want to go off and search these other tangents that people suggest and can't just click a link or actually find it via the search.
With that, "search archives on Hagens Explorer CV set up".... yea, I will just wind up reading the whole forum and find it one day!
I am going to set up a folder on my computer and save the different threads so I can go back and refer to them and if ever I post something and suggest something, hopefully I can just put a link to that particular thread.
Sorry, yes, I'm whinning... I'm going back to page-2 and picking up where I left off and will get caught up soon!!! I don't even have my Sidekick yet - just doing my research!!!
According to your experience,with a set up like the one I have now (Calmini 3"+3",Anvil-steel 3rd member-5,83 r&p's-Centerforce II-Warn premiun hubs-26 spline driveshafts-steering stabiliser-idler arm brace)
is it safe enough to install an automatic locker in front and which one do you propose ? What moves should I avoid when off roading ?
An other option is to put an LSD in the front axle,mainly to reduce stress,but .....its not a locker .....
(sorry for any mistakes I do,english is not my native language)
I have been locked in the front for years and never trashed a front housing :-/ I must be lucky from what I have heard about others experiances. I have trashed many half shafts and CV's. I recently upgraded to the Anvil w/ XL-7 3rd member (see article archives "Zig's Beef) I dont believe that you will have any trouble with a locker and the Anvil/steel 3rd set up. The problems that you will probably have will be with the CV's breaking under the extra force. Keep in mind that will be determined by your driving style and how heavy your right foot is. I drive my Kick HARD, and I expect to break stuff with the trails I ride and the vehicles I follow/lead through the trails.
If you are running manual lockout hubs there will be no difference of driving in 2wd than what you have now. Off road you will gain an incredible amount of traction with a front locker. Your steering will not be as tight turning in 4x4 with a locker and you will have ALOT more steering wheel pull from the wheels grabbing traction. With manual steering it can be tough to turn if the locker locks in, but I quickly learned to feather the throttle to lock/unlock the locker to allow turning.
I personally think you will enjoy being locked in the front, as long as you dont mind switching out CV's on the trail.
Also see the article archives on Hagens Explorer CV set up. It will be a good upgrade for you if you find yourself breaking CV's after installing the Locker
I hope this helps out,
