Trackota YJ - SAS Project Pictures
  • 85 Replies
  • 33869 Views
0 Members and 17 Guests are viewing this topic.
Re: Trackota YJ - SAS Project Pictures
« Reply #30 on: December 30, 2009, 10:45:21 AM »
Sounds like the perfect setup.
If you really need some help reviewing it you can send it my direction.  It would probably go great in the new race truck.  :D
Looking forward to the solid axle setup, is Sky planning on using YJ or Toyota springs?
  • 6558
  • 64
« Reply #31 on: December 30, 2009, 11:05:50 AM »
YJ.
Offline yellow2000S/R
  • 152
« Reply #32 on: December 30, 2009, 10:56:37 PM »
I'm somewhat interested.
Dont know how there is over $200 in 1/4" steel alone tho, I just got a 4'x4' piece of 3/16 from the local steel place and it was $52.xx. For a 4'x4' piece of 1/4" it should be around $70-80 and there's no way you have 4'x4' of steel in those brackets.
Regardless, I'm interested and would like to hear more about the "kit" and what all is required.
Any issues with moving the front axle setup forward 1.5-2" and the rear back about an inch?
« Last Edit: December 31, 2009, 12:20:29 AM by yellow2000S/R »
Offline MaddHatter
  • 81
  • Where is the Any Key?
    • MB GRAPHIX
« Reply #33 on: January 15, 2010, 03:58:24 PM »
Man, that looks great.  What are you doing for gearing?  Are you going the Kicker route?  Are those 33's or 35's?
Well, that part is open at the moment. I'm weighing options on power/gearing. A couple of proposed ideas are to run Stock 16 valve engine with a Samurai case behind the Sidekick transmission w/o the Sidekick case & 5.29:1 gears. Another idea is 5.29, stock Sidekick case w/XL7 V6. Another idea is Samurai case, Mercedes 300SD w/manual transmission & 4.10:1 gears. Maybe run a 1.9 TD VW engine with stock t-case and tranny & 4.10 gears.
The tires on it are 35 inchers...
Something like that. :)
Just let me know when you need the 1.9 TD
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« Reply #34 on: January 28, 2010, 04:26:29 PM »
Picking up an 84 SFA Toyo axle from bend this weekend.....oh boy. 5 hour drive in a diesel........for one axle. To get that. What pack are you gonna use on this project? 4/5?
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #35 on: January 29, 2010, 01:12:56 AM »
Hey minmatar, do you play eve online?
Sorry to post off topic, just had to know  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Minmatar
  • 262
« Reply #36 on: January 29, 2010, 10:59:09 AM »
I did.....4 years is more then enough time spent on one game........
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #37 on: January 30, 2010, 05:17:13 AM »
Hehe, yup, well I still do but not as active as I used to  ;)
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #38 on: January 30, 2010, 06:50:49 AM »
Amusing as I just started playing...
Offline Minmatar
  • 262
« Reply #39 on: January 31, 2010, 05:30:10 PM »
yeah I was i stopped playiing full time after TCT corp / LV alliance broke.
Offline Minmatar
  • 262
« Reply #40 on: February 03, 2010, 01:25:45 PM »
Ok im gonna start spaming this topic until i get an answer on kit prices....... >=l I refuse to let this subject get any lower on the totem pole of DIY.
Sky
Boon
LETS GET SOME PRICES!
  • 6558
  • 64
« Reply #41 on: February 03, 2010, 01:57:56 PM »
Sky
Boon
Did you call them?
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #42 on: February 03, 2010, 02:05:24 PM »
hey i have my 84 front axle for the kicker and am doing the leaf lift as well, its less parts to break...  curious though kinda new to this, but bolt on? i have been gathering parts and luckily i didn't buy the shackles and hangers yet, but can you show how the front frame got extended, i didn't want to weld that because of the fear of weakening the frame, but that is the  only struggle i have right now.
Offline 91zukisas
  • 140
« Reply #43 on: February 04, 2010, 03:04:50 PM »
I did the Toyota axles on mine, and used leafsprings, I did not need to extend the frame at all.
I will try to get some pics up soon.
I am running one of BOONDOX's protype sas kits.
Hopefully the kit will be on the market soon, I love it and have been running it for over a year now, with no issues
I know Steve at Boondox would have liked to have the kit on the market by now, but some things came up, that took priority over his business, so the kit got put on the backburnner
I started with the spring under version, but I think I am going to go spring over soon
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
Offline jawman
  • 406
  • 1234
« Reply #44 on: February 07, 2010, 09:39:02 AM »
how much is the axle? if you dont mind me asking
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
