Trackota YJ - SAS Project Pictures
  • 85 Replies
  • 33800 Views
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
Re: Trackota YJ - SAS Project Pictures
« Reply #75 on: April 05, 2010, 09:00:28 AM »
Do you have a 2d soft top? Kinda would like a new daily driver....
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
Offline jawman
  • 406
  • 1234
« Reply #76 on: April 05, 2010, 06:18:38 PM »
I have:
1989 2dr convertible body and frame.
1990 2dr tintop
1991 4dr needs some tuning
1994 4dr might need to rebuild the motor
1995 4dr in the middle of doing the head gasket
1995 2dr 4.3 GM V6 700r4 but I dont raelly want to get rid of it
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Minmatar
  • 262
« Reply #77 on: April 06, 2010, 10:09:23 AM »
Well if you ever get a 2 door soft top in. Nice and clean let me know. Im in the market.
« Reply #78 on: August 17, 2010, 01:16:48 PM »
Any updates on these kits?
Offline ZR2
  • 103
  • Powered by SUZUKI
    • See the best sidekick/tracker/vitara website!!!
« Reply #79 on: October 17, 2010, 08:35:24 PM »
i need info for this kit to!!!
Offline utahskibum
  • 76
« Reply #80 on: October 20, 2010, 06:27:05 PM »
I've recently talked with Low Range about converting my front end- it sounds like they are very close to having a kit ready and I will be starting on the swap this weekend. It is made for a samurai axle but can use a samurai to toyota axle kit.
« Reply #81 on: January 29, 2011, 08:24:34 PM »
hi i just purchased a 93 tracker an want to put yota straight axles under her do u have a number i can reach u at just want to ask some questions in reguards to your build im new to the tracker world took me along time find one than was in good enough shap to be worth messing with
Offline JRWperformance
  • I love YaBB 1G - SP1!
« Reply #82 on: April 10, 2011, 11:47:40 PM »
I guess Im helping to revive a year old thread. But this is good stuuf. Im in the market for this kit. The slayer is still pretty pricy but this kit I would pay good money for... Any updates? Is sky still going to carry the kit or low range? Any info would be greatly apreciated.
Offline utahskibum
  • 76
« Reply #83 on: April 12, 2011, 09:05:53 PM »
Just call Low Range Off Road- they have everything you need for the swap. I've been running mine for quite a while now and it has been great.
« Reply #84 on: May 10, 2011, 07:54:58 AM »
Low Range has it for the Samurai not the tracker, anyone know where I can get brackets for the Tracker???
Offline utahskibum
  • 76
« Reply #85 on: May 14, 2011, 12:38:55 AM »
yj springs are about 6" longer than sammy springs and will stick out further in the front hindering your approach angles. The mounting kit for the toyota axles is available for both yj or sammy springs but if you want to mount yj springs on your tracker front end you will have to build your own mounts out in front of the bumper. I think they stick out too far and when you add the shackles, there is a real loss of clearance and approach. I am running Trail Gear rear sammy springs with 3" of lift for my front swap and they are working good.
