Shop Drawing Suspension kit Sidekick (Gen. 1 Platform) 1989-1998
  • 102 Replies
  • 39940 Views
Offline PierPaul
  • 100
Re: Shop Drawing Suspension kit Sidekick (Gen. 1 Platform) 1989-1998
« Reply #60 on: February 20, 2012, 07:43:00 PM »
thank i very Impatien to receive it , Yes i was thinking about that and i finally decided to dont put rear light,hope i don't regreted.
« Reply #61 on: February 23, 2012, 09:22:09 AM »
Have you thought about just putting some really thick epoxy paint on the cardboard and running it?  It looks pretty good as it is and would save you some weight.  :D
Offline PierPaul
  • 100
« Reply #62 on: February 26, 2012, 05:38:59 PM »
Lot of work since my last reply first. i built a winch plate for receive winch and new front bumper. I draw in carboard my front bumper and draw in cad. Finaly i remove all part and cab and did a flip with the cab for finish weld my floor restore, after i use body sealer for all joint and weld. I finaly paint with a epoxy primer and bedliner coating. i very like the result very clean. i did the same thing with the inside i'm at the sealer state. I remove all part from the frame and paint it with epoxy primer i also start sandblast my rusty part for final paint
« Reply #63 on: February 28, 2012, 07:51:50 AM »
Wow, you are moving right along.  Nice stout winch mount.  I would add another lower/upper brace to stiffen it up horizontally (triangulate).  I know the bumper will do that somewhat (depending on its mounts), but just my thoughts.  I like the slope on the bottom edge of whole bumper.  That will help sliding up onto logs and rocks.
Might want a couple more coats of epoxy paint on the cardboard to help during wet weather. :laugh:
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #64 on: February 29, 2012, 03:47:32 AM »
Looks really good PierPaul, I'm working on designing my (some day) to be made setup in a 2d cad program (ProEngineer) as well. What program are you using? I am going to design a SAS setup which once it's done I will share over here as well. (got the chassis and axles in it working out the links atm). The only problem I have is time  ;)
Would you be willing to share your files so I can compare them to mine and see if my dimensions are a bit okay  ;D?
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline PierPaul
  • 100
« Reply #65 on: February 29, 2012, 05:03:27 AM »
ed oorklep, my sofware is Solidworks 2008 and yes i share you my file no problem
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #66 on: February 29, 2012, 06:11:16 AM »
Send ya a pm  ;)
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline PierPaul
  • 100
« Reply #67 on: February 29, 2012, 06:56:01 PM »
some picture of my paint job ... next step was body
inside body primed
inside body coated
frame coated
all part sandblasted
painted (Monster energy Green >:D)
missing on picture my a-arm was at welding
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #68 on: March 01, 2012, 03:37:07 AM »
Looks great, thanks for the file. Now I'm gonna have to work on it again tonight  >:D
Here's how far I have come so far:
View while working on it:
chassis by ed-oorklep, on Flickr
Quick render thingy
chassis2 by ed-oorklep, on Flickr
It's all designed to preserve the ride height I have now (with a 3" BL and 2.5" suspension lift) and 33"tyres.
I'll be working on the links and how to attach them to the frame now, and then steering will be the next issue to tackle...
chassis3 by ed-oorklep, on Flickr
Yours and mine in the same assembly, yours is the gold one, they're looking pretty much exactly the same so should be quite close to the real thing  8)
« Last Edit: March 01, 2012, 01:52:20 PM by ed oorklep »
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline PierPaul
  • 100
« Reply #69 on: March 01, 2012, 03:50:14 PM »
nice job, team work as about 3000 miles far,  i'm very interest in your sas design maybe you can share your file when you are done
Offline rockybaroofy
  • 38
  • doing what i can , with what i've got !
« Reply #70 on: March 01, 2012, 04:29:22 PM »
rust , hah ,. that's nothing !  i have three trackers and my best one is twice as rusty as that one !,,,  non kidding! rust is a major issue and i can and do fix or replace the rusted metal , but dont let it stop you if you run into it   ! lotsa luck with the project , keep us in the loop
'93 tracker pick-up daily driver
91 tracker 3"+3" 31's
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #71 on: March 01, 2012, 11:17:20 PM »
Yeah, nice team work indeed  :). I'll share my sas design when it's done off course.
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #72 on: March 02, 2012, 06:54:45 AM »
Nice "rustoration", this is a really inspiring build.
Offline PierPaul
  • 100
« Reply #73 on: March 06, 2012, 05:25:19 PM »
I'm in the last straight line, i finished today paint body part. (Note to myself, never retry paint a car in the shop) the result is not bad but im not very satisfied. I use paint gun and industrial black gloss paint, but it's a rig of trail . I hope friday i can get my steel for bumper and bolt for reassembled all parts ( i ordered zink plated bolts ) some pict of my body paint job and the part i'm the most proud, my  a-arm.
« Reply #74 on: March 07, 2012, 03:51:03 AM »
Amazing transformation. Thats a nice big shop you have there, so, are you retired? How do you find the time for all this?
