Project: Trouble
  • 129 Replies
  • 62805 Views
Re: Project: Trouble
« Reply #105 on: June 23, 2011, 11:19:34 AM »
Yea, they can be like that.  :)
What is your preference?  Other then cold and free?
« Reply #106 on: June 27, 2011, 12:03:04 PM »
Ok, a lot of work done this weekend.  Shock mounts are finished, new engine mounts are in place.  Basic wiring for the rear lights is done and we have tracked down another headlight.
Fuel Cell has arrived and we know how it will be mounted, but hasn't been mounted yet or plumed in.  Neither has the fuel pump.
Wiring needs to be completed, relays and switches need to be setup to run the headlights, brights, running lights and brake lights.
Side protection bars need to be installed.  Then the front seats re-installed.
Pictures from some of the updates will be coming later.
« Reply #107 on: June 29, 2011, 10:10:13 PM »
Picture Theater Time:
New jack from harbor freight, much easier to drag around:
Shocks from the outside:
And looking at the inside:
The other member of Trouble Racing, my brother:
Hood pins:
And one piece hubs so they don't fail like last time:
Full pictures online at https://picasaweb.google.com/105298426119042245963/RaceCar#
« Reply #108 on: June 30, 2011, 04:36:10 AM »
You are going to love those rear shocks. What valving did you get?
mine
« Reply #109 on: June 30, 2011, 07:37:47 AM »
mine
So much more room under there w/o the fuel tank.  I was concerned about running the shocks on the outside of frame because we had tire rub on upper inside of wheel well, and the shocks would be right there.  We have longer springs now, but to stay safe we ran them inside.  Also raised the mounting points to keep from catching them on rocks and things.  Didn't like them sticking that much below axle.
Your looks good under there.
« Reply #110 on: June 30, 2011, 10:46:02 AM »
mine
I'll have to look it up.  They feel pretty good back there though.
« Reply #111 on: July 05, 2011, 11:55:37 AM »
Ok, I have no idea what my current valving is on the shocks.  I'll have to try and track that down.
So work from this weekend.  So upon further testing we found that the switch on the key was bad, the 'on but not when starting' option was broken, but it ends up the power section of the key is pretty easy to rebuild.  So we now have a working ignition system.
The re-wriing of the motor from pulling the dash out is almost done.  But we have the motor running with the new fuel pump and the fuel lines run.  Now we need to finish up the plumbing (thanks Bigzook for the info) and mount the tank and the drivetrain should be just about back to where it was last year.  So the next major hurdle is wiring up the lights and mounting everything.  Then fixing the roof and some touch up paint.
Nothing like wrapping up at the last minute.
« Reply #112 on: July 08, 2011, 07:01:57 AM »
Ok, I should read more threads.  Fuel Cell and Firewall is in.  A little overkill on firewall, but was going from rules.  It is in and only a few gaps around roll cage.  Sealed the floor, so spilled gas can not  get into drivers compartment.
I know vent has to go outside of car, but that is the length of hose at hand for now.
Where to put spare tire now?
« Reply #113 on: July 11, 2011, 12:45:58 AM »
Wiring is done, dash is ready to be put back in.  Was stuck doing work for work all Saturday and slowed things down.
Not sure how pretty she will be when we get to Reno but we should be there.  But it's going to be tight...
« Reply #114 on: July 13, 2011, 01:36:46 AM »
So it ends up that the old radiator had a leak in it.  I can only assume it was one of the three radiators we tried out, all that had leaks in various places.  So another radiator goes in tomorrow.  It will match the water pump that started squealing at us.  So a busy day tomorrow as we are trying to get ready to leave.
Things to install:
Rear limiting straps
Emergency gear
Wiring for secondary lights
Headlights
Boat letter Z on all the numbers.
Then we probably call it good, load up and head down.
« Reply #115 on: July 22, 2011, 10:08:15 PM »
Ok, it was done.  Now that the race is over we can officially unveil why everything else took so long.  I would like to introduce the second half of Project Trouble:
Yea, a 2003 Suzuki Aerio with a 2.0L rated for 155hp.
BRD HNTR sizing up the exhaust.
Derek hard at work with the new motor mounts.
A shot of our drivers side motor mount, one of two on that side.  No worries about breakage there.
The difference?  Massive.  I was able to hit 85 on the straight stretches before I backed back down.  Anything over 65 I had to be in 4wd or the rear end started to move around to much.  Details on the next thread.
« Reply #116 on: July 22, 2011, 10:23:41 PM »
2.0L installation:
Bolted up to the stock transmission using a modified flywheel from Trail Tough.  The stock clutch worked fine, but did heat up a little on the initial 40 miles when doing a lot of climbing in 1st gear, so a 4 door clutch at the least is recommended, probably a Centerforce.  I stayed in high range the entire race.
Stock passenger side motor mount is used, but a mount coming from the motor was used.  For the drivers side two custom mounts coming off the frame were made using bushings instead of the stock rubber block.  They will not move.  After making them we realized they should be on the same plane on the frame to allow the engine some more movement, but it was to late.  For a dd we would design a bit differently.
Exhaust uses the stock pre-cat.  This allows us to keep the stock electronics in place.  We then go down to a flange with springs attached, a great way to keep your exhaust in one piece.  I ripped 3 mounts off the muffler and smashed in a 3rd of it on something, with the old exhaust we broke two studs off the header.  On this one, we just strapped the muffler back in place with some wire and went on our way.
The cooling system was an issue.  Due to the water outlet going straight back we had to cut a hole in the firewall and do a 180, then bring the cooling line back above the exhaust and route it into the stock radiator.  With a 2.0L Tracker rear outlet it is already coming out 90 degrees, and you could keep the lines inside the engine compartment.  Without a heater our way worked just as well.  And faster.  The electric fan relay is wired to an AC over-ride that kicks on at 215 degrees.  A bit hot but serviceable.  We didn't need the fan as long as the car was running above 25, it air cooled nicely.  Stock radiator and the fan is from an AC Tracker.
Computer wiring.  This was done by BRD HNTR with experience gleaned from his V6 build.  Everything runs into the stock Aerio computer, just on the passenger side instead of going in the drivers side.  The engine does not run error code free, partially due to this being an automatic.  If we were using a manual then many of the error codes would be gone.  But we were able to monitor everything via the ODBC II connection, it all ran.
The dash is stock.  The tach was connected to the computer and stock speedometer is used.  The oil light should work, but the temp gauge did not.  So BRD HNTR plumed in a new temp sensor, we wired the temp gauge directly to it and it works fine.  It's not an exact gauge, but it works.
Serpentine belt, didn't work quite right.  By default there is an AC pump and Power Steering box, neither of which we use.  So we had to track down an AC bypass pulley to install where the power steering pump normally went.  A custom bracket and it bolted up fine, but a bit to tight.  Eric helped us find out that the reason for an idler pulley squealing was the belt was to tight.  A 1" longer belt and she ran great, until the belt disintegrated 55 miles into the race.  The stock belt went back on, stretched out and ran without issue for another 80+ miles.  So chalk that up to a bad belt.
Air filter is an off the shelf K&N.  It was coated with dust and then some by the time we stopped.  Next time we need to build a housing for it and route it into the cab to help keep as much dust off as possible.  Or at least run a pre-filter.
Hood pins.  The hood is held on by pins, I thought they were left off at a pit stop, but thanks to my GoPro HD Camera I can watch one slowly back out and the second fly off when I hit a big bump.  Then up comes the hood!  So next time, locking hood pins.
Final thoughts:  A lot of work, but she was wicked fast.  A shame BRD HNTR didn't get a chance to drive it.
« Last Edit: July 22, 2011, 10:52:09 PM by Drone637 »
Offline Jluck
  • 1389
  • 40
« Reply #117 on: July 23, 2011, 04:34:53 AM »
Sneaky! That looks like a decent donor car there. That should be a screamer. I like that family of engines.Waaay cool
« Reply #118 on: July 23, 2011, 07:53:44 AM »
The donor car had just been T-boned.  Price was right, and then I stripped and sold parts, and rest of car to start the conversion at par.  It is a sweet engine and has much more power than Drone's 1.6 16v.
Also needed to change out oil pan and pickup tube.
« Reply #119 on: August 25, 2011, 02:13:53 PM »
Video of the first 1:30 of the race:
2011 Vorra USA 500 - Start to Break
Embedding by Aeva Media, © Wedge
