Project Kickota
  • 133 Replies
  • 33608 Views
Offline v-stone
  • 625
Re: Project Kickota
« Reply #75 on: September 14, 2009, 12:08:01 PM »
Looks good.
SAS Tracker! No looking back now.
Offline Praise Him
  • 256
Re: Project Kickota
« Reply #76 on: September 17, 2009, 04:08:23 PM »
Time to upload some video.
How are you liking the Auto?
sammy/toy axles/locked/geared/cased/36's
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Project Kickota
« Reply #77 on: September 17, 2009, 08:22:26 PM »
Thanks guys. I absolutely love the auto everywhere except the highway. It makes wheeling so much easier and allows me to concentrate on where I want my truck to go instead of which foot needs to go where. I can also put it in 1st and low-low and not use the brake going down a 45 degree incline. The Irok's hook up like mad, I'm very impressed with them. A little too much traction as on the first good run I gave it the upper x-member that holds the rear diff snapped in half so I'm rebuilding that now.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline KJMac
  • 280
Re: Project Kickota
« Reply #78 on: June 08, 2010, 08:53:09 AM »
Sweet setup! What transfer case setup are you running? is it an adapter that can be purchased?
Thanks!
KJ
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline biker
  • 730
Re: Project Kickota
« Reply #79 on: June 10, 2010, 06:24:41 AM »
I'm running a Kicker2 from OTT Industries. Stock gears in the front case and 4.7 to 1 in the Toyota case
99 Vitara 2wd
10 Gr Vitara
Offline nathanvit
Re: Project Kickota
« Reply #80 on: January 08, 2011, 03:59:58 AM »
hi biker,
im new on here and have just read your build (good job by the way), just wondering how your front arms have held up. i have a 91 swb and im doing a sas on and looking for ideas for control arms.
cheers nathan
Offline biker
  • 730
Re: Project Kickota
« Reply #81 on: January 08, 2011, 07:07:57 AM »
Thanks for the compliment. I have had zero problems with the front arms and have beat them hard. I had to remove the rear lowers due to the rubber bushings breaking down and therefore causing a rear steer problem. I put longer lowers in with poly bushings at the front and creeper joints at the axle. I also installed some rock rings on the rims as they were starting to get bent up.
99 Vitara 2wd
10 Gr Vitara
Re: Project Kickota
« Reply #82 on: January 15, 2011, 10:42:17 AM »
Awesome Job and Awesome Rig!
Re: Project Kickota
« Reply #83 on: January 19, 2011, 05:31:42 AM »
The machine looks awesome. I like the idea of the fenders all over the body. its great. If you paint it carbon black it will look great its just a suggestion.
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
Re: Project Kickota
« Reply #84 on: January 22, 2011, 04:58:38 PM »
Is the pipe exo cage holding up good? any roll overs yet!
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Offline biker
  • 730
Re: Project Kickota
« Reply #85 on: January 23, 2011, 07:09:36 AM »
Cage is doing well. No rollovers yet but I've slammed it into trees and rocks with no damage other than scrapes
99 Vitara 2wd
10 Gr Vitara
Re: Project Kickota
« Reply #86 on: August 27, 2011, 06:13:19 AM »
Any updates? Nice build.
Offline biker
  • 730
Re: Project Kickota
« Reply #87 on: September 04, 2011, 09:10:10 AM »
Not much to report at this time. Got married and house reno's have been taking up most of my time. My daughter managed to hit a ditch with it and bent the front housing so I had to make it better and stronger this time. Hoping to go camping and wheeling for a few days next week so maybe I'll have some more pics after that.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #88 on: September 04, 2011, 09:11:24 AM »
After
99 Vitara 2wd
10 Gr Vitara
Re: Project Kickota
« Reply #89 on: September 09, 2011, 04:00:43 PM »
Nice added bracing.  Let us know how it holds up next time she drives in the ditch.  :D
