Build Diaries, How-To, DIY
Project Kickota
Pages:
3
4
9
Project Kickota
biker
730
7
It's a sickness I tell ya
Re: Project Kickota
Reply #15 on:
February 02, 2009, 04:22:37 PM »
I just hope it works good after I'm all done
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
91zukisas
140
Re: Project Kickota
Reply #16 on:
February 09, 2009, 06:18:28 PM »
Looking good
Cant wait to see it done
91 2door Sidekick yota Axels SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
RHodge
523
Re: Project Kickota
Reply #17 on:
February 09, 2009, 08:51:22 PM »
Yes, looks good
biker
730
7
Re: Project Kickota
Reply #18 on:
February 10, 2009, 06:41:54 AM »
Thanks guys. I almost got the rear finished now so when I do I'll update with a couple pics. Next step is to pull the motor,trans and case and replace.
99 Vitara 2wd
10 Gr Vitara
biker
730
7
Re: Project Kickota
Reply #19 on:
February 15, 2009, 07:38:37 PM »
Well I got the back springs put in this weekend and hooked up the brakes, still waiting on E-brake cables. I decided to try out some TJ coils for now and see how they flex.
99 Vitara 2wd
10 Gr Vitara
biker
730
7
Re: Project Kickota
Reply #20 on:
February 15, 2009, 07:40:46 PM »
A couple more, just because
99 Vitara 2wd
10 Gr Vitara
biker
730
7
Re: Project Kickota
Reply #21 on:
February 15, 2009, 07:42:48 PM »
Next step is to pull the motor and trans out along with the wire harness and replace it with a 1.8, 4spd auto, Kicker2 with 4.24:1 gears in the front case.
99 Vitara 2wd
10 Gr Vitara
Lindenmooch
560
Just another paranoid android.
Re: Project Kickota
Reply #22 on:
February 15, 2009, 07:55:31 PM »
SUHWEEEEET!!!!
Nice job! I wish mine was that high!!
Pics of my favorite money pit can be seen at the link below. =)
http://i33.photobucket.com/albums/d51/hornetking/1995%20Suzuki%20Sidekick/10174942_10152854812071978_8633283016569018530_n.jpg
91zukisas
140
Re: Project Kickota
Reply #23 on:
February 15, 2009, 08:43:48 PM »
NICE WORK
91zukisas
140
Re: Project Kickota
Reply #24 on:
February 15, 2009, 08:47:49 PM »
the 36" tires look perfect
zukizuki07
251
Re: Project Kickota
Reply #25 on:
February 15, 2009, 10:00:54 PM »
have you measured your fender-ground?? i keep going crazy looking at those pics and trying to figure out if the rear is lower than the front.
96 2 Door Tracker
Plans: Jeffs diff spacer, bumpers, smittybuilt 8k winch and XL7 iron Diff. housing swap
RACER X
383
zuki or die!
Re: Project Kickota
Reply #26 on:
February 15, 2009, 10:42:34 PM »
front just needs a winch
98 kick
biker
730
7
Re: Project Kickota
Reply #27 on:
February 16, 2009, 06:36:51 AM »
The tires on it are 315/16's and are supposed to be 35's but only measure just over 33", the Irok's will be a little bigger.The front is a little higher than the rear but I have to install my bumper with winch and a cage yet so I'll see how it sits after that and adjust as needed. Thanks for the comments
Last Edit: February 16, 2009, 06:40:06 AM by biker
99 Vitara 2wd
10 Gr Vitara
25
Re: Project Kickota
Reply #28 on:
February 17, 2009, 07:25:35 PM »
Great job on the 4 door... Looking good
biker
730
7
Re: Project Kickota
Reply #29 on:
February 17, 2009, 08:03:03 PM »
Thanks Zig, I've been drooling over your new toy myself
99 Vitara 2wd
10 Gr Vitara
Pages:
3
4
9
