just got my tracker a few weeks ago for 500$ its a bit of a rust bucket but it runs good. the previous owner called it "rust red" so that's what i'm deciding to call it
. the body is rusted and a lot of stuff under it is rusted but the frame rails are pretty much rust free and have no holes in them. it has a new motor the previous owner put in and it runs like a champ. the plan for it is to keep it a mild build and have it street legal but still good on the trails. i don't think i will be lifting it but i do want to have some more clearance so i will be going for a low c.o.g. style rig.
here is what is started out as.
well the madness started when i started smelling gas in the cab. i looked and gas was pouring out of the rear from above the gas tank. i decided to drop the tank to see where it was leaking from. it was spraying out in a steady stream from the fuel line from the pump. once we got the tank out we saw that the rear cross members were completely rusted out. we pulled the plastic part of the bumper off to find that the metal under it was pretty rusty.
we decided to pull out the plasma cutter and cut off the rear bumper completely. the rear cross member was so rusted out that once we cut the bumper mounts off we just pulled the bumper and cross member out as one whole unit.
the next step will be to get some 2"x4" square tubing and make a rear bumper/cross member out of it. since there is so much more clearance in the rear with the bumper and fuel tank gone we were thinking of either putting the fuel tank in the cab where the rear seat is and cover it with a wooden box with carpet attached to it so it looks like its not even there OR just mounting it higher up under the tracker if we can.
