So, a few of us are going out wheeling this weekend and I got ambitious. I've wanted to lift the front for ages, and as I said in a previous post I was inspired by the photo of a chopped and dropped control arm. I figure, hey, if you can do it to lower you can do it to lift too. So here I go:
The original measurements for frame clearance are 8.5" front and 10" rear.
I was tired of the front tires rubbing on the kickboard/firewall so I wanted to move the tires forward. If you've ever looked under your rig, you'd notice that the cv axles actually angle to the rear. Why? I don't know. A combination of lifting, widening, and extending was my goal.
I fab'd a new balljoint mounting plate and chopped up the A-arm. Put it where I wanted it then re-enforced it. The new location for the ball joint was 2" forward, 1.5" down, and 1/2" wider. I repeated the process for both sides. Throughout the process I checked and double checked that there was not rubbing or binding or hitting throughout the travel and steering changes.
Then I painted and installed them. I flipped the strut mounts to get back some of my suspension travel, but I think I need to upgrade to the OME ones. When it was all installed I ended up with 2 inches of lift in the front. To level it out I laser cut 3/4" spacers for the rear. I had already installed crown vic shocks, so the spacer install was easy.
To finish off I measured the frame, front and rear to get the after measurements...
10.5" front
11" rear
I measured the fender to tire and found them to be the same front to back. So now it's got some mad clearance (compared to stock). The control arms are up out of the way giving equal ground clearance across the whole underside.
Time to go wheelin'
If you have any questions ask away!
P.S. - My reasoning:
If I didn't explain it well enough before, my intent was to lift the Tracker enough to get some decent clearance without sacrificing much stability. I guess for me the optimum height for stability/clearance is when the centerline through the axles line up with the bottom of the undercarriage.
I'd love to hear your comments!
