tiger tracker gets SAS'd
  • 42 Replies
  • 9767 Views
Offline Lindenmooch
  • 560
Re: tiger tracker gets SAS'd
« Reply #30 on: February 14, 2009, 01:09:20 PM »
Agree.  Congrats.
Offline TopHeavy96
  • 488
« Reply #31 on: February 14, 2009, 11:51:35 PM »
Yeah looks good, I wanna do that to my 4 door!!
« Reply #32 on: February 17, 2009, 02:38:25 PM »
 :D  death wobble gone .yea   after checkin the caster angle twice ive got abot 5 deg pos. caster that very close to stock only 1/2 deg off . so i start recheckin things , turns out when i changed the tierod last week i didnt get the toe adjustment right it was 3/4 inch wider in the front than the rear readjusted to about 1/2 inch less in front than back . abd tada wobble gone even at 55mph  . i guess i read  the tape wrong when setting it last time . thanks all for the help.
« Reply #33 on: February 17, 2009, 02:51:39 PM »
Nice looking conversion.  :)
On a side note, I like the brush guard.  :D
« Reply #34 on: February 17, 2009, 03:01:08 PM »
thanks i built that grill guard  out of scrp metal lieung around lol turned out pretty good .
Offline Praise Him
  • 256
« Reply #35 on: February 27, 2009, 01:37:09 AM »
Sweet ! I have always wanted to SAS a tracker, Ive done toy axles under sammy's but never a track or kick.
Right on :)
sammy/toy axles/locked/geared/cased/36's
Offline v-stone
  • 625
« Reply #36 on: March 17, 2009, 08:40:31 PM »
What size wheel spacers did you use? Does the front match the back in width.
SAS Tracker! No looking back now.
« Reply #37 on: March 25, 2009, 10:17:22 AM »
i used 1.5 inch spacers the front is just a little smaller than the rear but not bad
well i took it out a couple times now . everything is working pretty well.
Offline Lindenmooch
  • 560
« Reply #38 on: March 25, 2009, 03:46:51 PM »
Excellent work!  Looks great!!!
Offline Amilla
  • 1076
« Reply #39 on: March 25, 2009, 05:03:55 PM »
Did you loose any front ground clearance?
My buddy has a sidekick, he keeps blowing up the front end.  So i gave him my old front sami axle, for him to SAS it.  Hes hasnt done anything to it yet because hes afraid hes going to loose a bunch of front end ground clearance.
Looking good by the way!
Amilla
Offline Lindenmooch
  • 560
« Reply #40 on: March 25, 2009, 05:09:39 PM »
Why would he lose ground clearance?   If you mean because of the straight axle versus the IFS...then maybe like...an inch?
BUT...if you clear a rock or log with the front because of the way the IFS is setup....you still have a solid axle in the rear to think about.
AND....I thought ground clearance was only truly gained with larger tires.  Sure...you can get your body/frame off the ground with taller springs.....but you'll still bash the crap outta yer axles unless you have big tires.
Offline Amilla
  • 1076
« Reply #41 on: March 25, 2009, 05:53:33 PM »
A straight axle hangs down quite a bit more than IFS, not only just the axle.  In spring under set up you have the springs, U-bolts and U-bolt plates hanging down, not just the diff (other than bashing the front diff into the ring gear).
IFS
SAS
Even thou there are more things to snag on with a spring under set up, the strength of a solid axle compared to IFS out weights the loss of clearance.
Bigger tires are definitely the best way to gain clearance, but if you cant go to a bigger tire or choose not to.  You can shave the diffs, SPOA, high pinion 3rds, or switch to a custom high clearance axle.
Amilla
« Reply #42 on: March 25, 2009, 06:41:24 PM »
honestly i cant tell any diff in ground clearance , face it the little sammy axle is almost too short to worry about high centering much ,with it moved forward i get a better aproach angle despite the low hanging shackels , but the off road ride and stability is awsome .no more 3 wheeling with a front tire hanging in the air and harsh front end bashing when you hit a hole because of little or no down travel . i love it it walk through places it used to lift a tire and slide side ways cause only the locked rear had traction.
