Just another SAS Tracker
  • 24 Replies
  • 15147 Views
Offline allout
  • 41
« on: February 22, 2011, 04:44:20 PM »
Hey all. I have been around this site for a while and thought I would finally post up some pics of my 94 Tracker. It is nothing special but it gets me to where I wanna go. I bought this with the idea of it being my dd/wheeler and it has performed that dual role very well. As we all know the bigger, better, faster bug hits and the line between dd and wheeler becomes obscured. Right now it is still my commute vehicle and used when the wife is out with the other vehicle. Enough babbling. Here are some pics.
This is when I got it.
Shortly after buying it I had to lift it and put 31's on it
My goal is to run 35's so I installed a 2" body lift. When I did that I found the rear crossmember had some rot so I cut it out and put some tubing in to take its place. I thought it was a good time to raise the gas tank also.
« Last Edit: February 22, 2011, 05:02:55 PM by allout »
94 Tracker, SAS with YJ's, spartan locker front , welded rear, 33/10.50's, 4.24tcase gears, Warn M8000. Toy axles being built up.
Offline allout
  • 41
Re: Just another SAS Tracker
« Reply #1 on: February 22, 2011, 04:49:33 PM »
So I wanted an SAS so this is the start of it
85 Samurai axle with Spartan locker. YJ leafs
And back on its wheels just 31's
« Last Edit: February 22, 2011, 08:01:47 PM by allout »
Offline allout
  • 41
« Reply #2 on: February 22, 2011, 04:55:53 PM »
More pics
Now on 33/12.50/15's
« Last Edit: February 22, 2011, 05:01:03 PM by allout »
Offline allout
  • 41
« Reply #3 on: February 22, 2011, 04:58:48 PM »
Just finished my bumper with a Warn M8000 winch. The control box is under the hood. It is also now sitting on 33/10.50/15's
It also has a Spartan locker up front, welded rear and 4.24 Tcase gears.
« Last Edit: February 22, 2011, 05:26:08 PM by allout »
Offline joe dirt
  • 148
« Reply #4 on: February 22, 2011, 05:56:00 PM »
looks great...kinda reminds me of another one on here.... 8)
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Offline allout
  • 41
« Reply #5 on: February 22, 2011, 07:58:12 PM »
LOL, Thanks Joe, yea there are a few around that look the same.
« Reply #6 on: February 24, 2011, 12:21:56 AM »
Did you try to synchronize your icons or was that just a happy coincidence?  :D
It looks good, what are you running for gears in the axles and how does it drive on the road?
Offline allout
  • 41
« Reply #7 on: February 24, 2011, 05:57:38 AM »
Thanks Drone. LOL I just noticed that now that you mention it. I am running 5.13 gears. It is ok on the road but definately sluggish compared to stock. Fortunately for me I am about 5 mins away from the start of my usual wheeling spot. This is my dd but my commute to work is fairly short. The 4.24 gears are a must for offroad. I am either going to do a doubler or just buck up for an undertaker. I have a set of Toy axles that I am rebuilding with 5.29 gears and want to go with 36-37" tires.
Offline smife
  • 179
« Reply #8 on: February 25, 2011, 07:13:09 AM »
Nice clean Tracker allout!!! I'm digging the chrome sims in the first pic. :)  I'm thinking of putting a set on the wifes Tracker because she said stock it looks like an old mans Tracker.
Where did you mount the control box for your winch under the hood? I have enough room on the passenger side up front by the radiator but I really don't like it there.  With the battery in the stock location I'm having a hard time finding a good spot.
Offline allout
  • 41
« Reply #9 on: February 25, 2011, 07:47:02 PM »
Thanks smife. Funny thing is those are not chrome rims but just some cheap plastic hubcaps that you would buy from Walmart. They came with the Tracker. They looked good from afar but up close looked bogus. I mounted the control box where the windshield washer bottle sits. Right now I am running without the washer bottle but found a smaller one to mount in a different spot.
Offline smife
  • 179
« Reply #10 on: February 26, 2011, 08:37:22 AM »
Thanks allout. I thought those hub caps where "sims" my spelling may be wrong. They are like a wheel "skin" That is chrome. All the new vehicles have chrome sims instead of chrome rims. Its just a plastic hub cap but it conforms to the wheels shape.
I still have my washer bottle. I actually put dual squirters on my cowl panel for maximum winshield cleaning.
Offline joe dirt
  • 148
« Reply #11 on: February 28, 2011, 09:22:08 AM »
heres where i relocated mine,..had to put the air cleaner in its spot
Offline allout
  • 41
« Reply #12 on: February 28, 2011, 05:49:22 PM »
Thanks Joe. As a matter of fact I just put mine in that exact spot today. It pretty much fits like it belongs there.  ;)
Offline THETRACKER
  • 6
« Reply #13 on: February 28, 2011, 11:34:38 PM »
one quick question, how did you do your rear?
Offline allout
  • 41
« Reply #14 on: March 01, 2011, 07:43:20 AM »
The rear was pretty simple. Just used XJ coils and cut just enough off the coil to fit over the bump stop tube. Extended the stock bumpstop tube and captured the coil on the axle. I did this because I had the coil pop out a couple times. I have cavalier rear shocks and made lower shock mounts that are higher up on the axle. I had purchased a spare rear axle and it came with a modified Y link. They had cut the center out of it just enough to weld a piece of tubing in then put a huge threaded bushing on the end. Welded a bracket on the top on my housing for the bushing to fit in. It works but is kinda bogus. I have already made another Y link and will do it better when I move the axle back and extend the lower links at the same time.
